stance coilover owners, post your damper settings
Old Jun 22, 2010 | 12:54 AM
nyckid's Avatar
To any of you guys who are running on Stance GR+ coilovers on their g35 coupes. What are your front/rear dampers set at?
Would like to know what a good setting to have the rears at for those of you who are slammed on 20's with aggressive offsets in the rear running on stretched tires.
Old Jun 22, 2010 | 02:07 AM
zhao's Avatar
04395843 fronts and 9458498543 rears.
Old Jun 30, 2010 | 04:01 PM
The Stimulation's Avatar
Don't have a coupe, but I have the sedan, slammed, very aggressive 20's..i have mine on the stiffest. Still smooth too.
Old Jul 7, 2010 | 04:35 PM
nyckid's Avatar
woudln't this shorten the life of your shocks much quicker though?
Old Jul 7, 2010 | 04:37 PM
CandlestickPark's Avatar
ill Sedan
Most guys slammed on 20s (or 19s) with agressive offsets are running full stiff to prevent/reduce rubbing.
I'm at full stiff F/R on BC Racing coils.
Old Jul 7, 2010 | 04:38 PM
Frankieg35's Avatar
I'm at full stiff in the front and 8 in the rear.. I plan on matching the front..
Old Jul 7, 2010 | 05:10 PM
nyckid's Avatar
damn wish i knew this sooner before i took the rear shock out. I have it dialed at 10 in the rears.
Old Jul 7, 2010 | 05:17 PM
Frankieg35's Avatar
10 should be fine.. I'm good at 8 and rub slightly on dips..
Old Jul 7, 2010 | 05:18 PM
Johnnyone's Avatar
^ good thing it's an easy fix. just take off the wheel and remove two 12 bolts on top of the shock housing, adjust, put shock back and wheel back and your done.
And u could leave it at 10 if your not bottoming out.
Old Oct 29, 2012 | 03:31 PM
Big Booty Trudy's Avatar
So what would y'all recommend for the rears? I should be getting mine this week and I want to set my rears right the first time because I heard you can't adjust on a coupe without drilling holes will be dropped on oem 19s. Looking for a comfortable ride. Thanks guys
Old Oct 31, 2012 | 02:54 AM
Anyone?
Old Oct 31, 2012 | 08:33 AM
aa2033's Avatar
I'm at 15F and 13 or 14R (forgot which). I don't bottom out or rub at all in the rear, but I also have rolled fenders and the camber adjusted to avoid it even if I was on a softer dampening.
Now I'm curious, does having your stiffness high wear out the coilovers considerably faster?
Old Oct 31, 2012 | 12:51 PM
VMRWheels's Avatar
+1
It will really depend on how your car is setup. If you don't have much clearance you'll probably end up setting your suspension stiffer.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
