Help with my alignment sheet
Old Jun 30, 2010 | 03:39 AM
EnJoiLuv's Avatar
Hey guys, I just got my alignment done at Nissan. Can someone help me with this? Do I need a camber kit for the front because I cant tell which one is my camber? And I dont reccomend Nissan for alignments because they dont give you a before and after spec sheet.They only give you an after spec sheet. And the dumb technician scraped my car going up the ramp when I already warned him that it's going to. And can anyone tell me why my car is still pulling to the right even after I got an alignment...? Thanks in advance guys!
BTW, Im dropped on Eibach Pro-Kit springs and stock 19's w/ 225/35/19 F and 245/35/19 R
Here's the spec sheet:
Old Jun 30, 2010 | 02:27 PM
gabe3d's Avatar
Holy smokes.... your camber is off the chart and it couldn't be measured. Surprising that it is so off considering that you are only dropped with the eibach and don't need excessive camber to prevent rubbing. How does the car look camber wise?
Old Jun 30, 2010 | 02:38 PM
03threefiftyz's Avatar
I don't even see camber on there.............only caster and toe......which are not too terrible.
Old Jun 30, 2010 | 04:24 PM
idrive_MD's Avatar
ditto, chart is misleading, camber is not even listed. everything seems ok otherwise, odd they dont even show the camber. I would ask them to check the system to see if they have a value for it, otherwise we can't help much. Toe is a bit more important on our cars in terms of premature wear.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
migurus
Sep 5, 2015 09:39 PM
