350z/coupe spring setup
Old Jun 30, 2010 | 01:40 PM
GhostfaceKillah's Avatar
So I want to do the whole 350z/coupe springs setup on my 03 sport sedan. Before I order my parts, can someone tell me if it matters what year z/coupe the springs come out of? Also, if it needs to be revised/unrevised?
Old Jun 30, 2010 | 02:39 PM
cato's Avatar
SouthernComfort Moderator
Yes, I just installed the full 350z suspension. I love it.
It must be the "revised" suspension. The revised suspension, was introduced by Nissan in 2005 for the 350z. So if the springs you buy are from a 350z older than 2005, they are unrevised. The unrevised springs will cause your car to bounce around on the highway, or "porpoise". See my thread
https://g35driver.com/forums/brakes-...uspension.html
Old Jul 1, 2010 | 01:24 AM
Cool, now what should I know about the coupe springs?
Old Jul 1, 2010 | 06:07 AM
cato's Avatar
You will need to do some reading on your own! I know nothing about the coupe setup, but it has been discussed at length..........
https://g35driver.com/forums/brakes-...nsion-pix.html
Old Jul 1, 2010 | 01:20 PM
brandon1978's Avatar
The OP only mentioned he was changing springs. The bouncing problem is with unrevised 350z struts/shocks; the springs have nothing to do with it. 350z front springs were the same every year.
When you get your springs, check the colored dots to make sure they are what you were expecting. The first time I bought springs from someone in the marketplace, I received a box of four springs from three different cars! The info for all the different colored dots can be found in the middle of this thread:
Old Jul 2, 2010 | 03:34 AM
sweet. thanks guys!
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
