Lowered my coupe, some alignment questions
Old Jul 15, 2010 | 08:25 AM
eonx's Avatar
I have an 06 coupe 6MT and I just recently had put on coilovers, front/rear camber arms and wheel spacers (20mm front, 25mm rear). With my OEM 19s on the car, the car is about 1" lower in the front to 1.25" in the rear which is just low enough where I don't think wheel rub will be a concern. However, since I am that low, my front wheels do have some pretty noticeable camber to them, more than usual.
My alignment read out:
Front left camber: -2.1
Front left toe: 0.02
Front right camber: -2.1
Front right toe: 0.02
I'm glad the toe is in spec, but to me it seems -2.1 is pretty far out of factory spec. Is it that far out that I should worry about tire wear?
I completely forgot to ask the shop if -2.1 was the best they could do, maybe I'll call them up. But if that's the best it's going to get, I assume I'd have to raise my ride height some to correct it?
Thanks,
Old Jul 15, 2010 | 08:28 AM
JBF's Avatar
JBF
I run -2.8 with no issues
you're good
Old Jul 15, 2010 | 08:32 AM
EL-EE-ES's Avatar
there is no camber adjustment on the front, youll need a camber kit or have to raise it to get into specs if thats what you want...
Old Jul 15, 2010 | 08:35 AM
JBF's Avatar
JBF
^ he has a front camber kit as stated in his post
eonx's Avatar
See above, I bought a front and rear adjustable camber kit. Which is why I'm assuming -2.1 camber in the front was the best the shop could do.
Old Jul 15, 2010 | 08:44 AM
EL-EE-ES's Avatar
sorry, what camber kit did you get
Old Jul 15, 2010 | 08:58 AM
eonx's Avatar
I got Ichiba front and rear. Any chance it's not as adjustable as some of the other kits?
Old Jul 15, 2010 | 09:09 AM
EL-EE-ES's Avatar
ichiba says that they have a -/+3 dergree adjustment. being lowered an inch, they should be able to get you into spec. i would go back and see what they did
rezendvous420
May 31, 2020 01:26 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 23, 2015 09:26 AM
Soumilg
Jul 18, 2015 12:33 PM
