camber kit??? on eibach pro kit and 20" wheel
Old Jul 15, 2010 | 03:29 PM
bolacbolac's Avatar
do I have to install a camber kit on my g35 coupe 2005 if I install a eibach pro kit coil spring (1'') on a 20" wheels
thx and sorry for my english
Old Jul 15, 2010 | 03:45 PM
The Stimulation's Avatar
That depends. Do you mind a little bit of negative camber or do you want your wheels in spec?
It's not camber that you should be worried about, but mainly the toe. With a 1" drop you don't need anything except for an alignment. But wait a little bit after installing the springs to do the alignment since they will settle. I would wait about 500-1,000 miles and then get the alignment done.
Old Jul 15, 2010 | 04:16 PM
bolacbolac's Avatar
the wheel spec is :
front: 20" X 8.5, lip 2 1/4' 5 x 114.3 (MRR Design GT1)
back: 20" X 10.0, lip 4' 5 x 114.3 (MRR Design GT1)
I tell the question because I don't need to scrap my tires in 1 summer (+/- 1 000 miles) and I don't need problem with my car... I just like the look when the car is dropping
same car, color and wheel... but mine is not dropping
Old Jul 15, 2010 | 04:19 PM
I meant back into factory alignment specs, not wheels specs.
wuppiedog
Aug 7, 2015 11:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 23, 2015 09:26 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
