where do these brake pad shims go? (pic)
Old Jul 27, 2010 | 09:27 PM
obsdnoblivion's Avatar
http://i237.photobucket.com/albums/f...o/CIMG2181.jpg
The silver parts, I mean. They came as part of the hardware kit I bought for the fronts from everythingg35.com. The pads came with the gray shim holder things too, so I don't need the ones from the kit. I think I may have wasted money on that kit. But I can't figure out if the cut out part goes toward the front of the car or the rear. I'm pretty sure they go next to the pistons. Somebody help me make sure I put these things on correctly!
Old Jul 29, 2010 | 12:36 AM
tonke73's Avatar
You can reuse the OEM shims that came off your pads. I don't think it will matter if the cut out goes towards the front or the rear on your front pads. There is a shim post further down in the brakes and suspension section.
I reused the OEM shims from my pads when I replaced my rear pads.
Old Aug 2, 2010 | 08:10 AM
Thanks, man. I saw an exploded view in the brake manual I downloaded and they cut out part is toward the rear. But yeah I was thinking it didn't matter much.
Old Aug 10, 2010 | 03:06 PM
Mr. Samster's Avatar
The ones in the manual are the old one... The ones that you got are the redesigned ones.
Jiggerjuice
Oct 5, 2015 02:33 PM
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
