Approaching 80K, what bushings to replace?
Old Sep 2, 2010 | 10:42 PM
G35fromPA's Avatar
Originally Posted by Andrei
You're not suppose to use polyurethane Whiteline bushings in suspension components. That's why car makers only use rubber. Get the Nismo hard rubber ones instead.
Carmakers use rubber because rubber provides a more compliant ride and has less NVH than polyurethane, and thus results in fewer complaints from owners. But the whiteline bushings have a lower durometer (hardness) rating than other poly bushings, so should be fine for the street.
Old Sep 3, 2010 | 12:15 AM
GT-ER's Avatar
Exactly.
Old Sep 3, 2010 | 02:15 PM
Andrei's Avatar
Originally Posted by Row2k
where are you getting this, please do not spread misinformative blanket statements like that. There have been numerous users on my350z who have used the whiteline polyurethane bushing in the front lower transverse link as well as rear subframe bushings. The only person that has run into issues with whiteline polyurethane bushings was a user who installed them in the rear knuckle and ended up with his spl camber arms damaged. This HOWEVER was not confirmed to be caused by the bushings and even IIRC kuah from SPL jumped in and said the damage was most likelly caused by strapping the car down to the dyno by the control arms. So take it for what it is, there has been NO substantial evidence to say that you are NOT SUPPOSED to use polyurethane bushings in the suspension. Granted there are points such as the inner compression arm bushing where a free pivoting bushing needs to be used and a polyurethane bushing will bind big time.
It does make me wonder why Nismo chose to make hard rubber replacement bushings instead of polyurethane. Maybe because polyurethane doesn't allow the suspension to articulate the way hard rubber would or solid bushings would.
Certainly Nismo with decades of experience building and racing race cars they must know something no one else does and that's why they make hard rubber bushings instead of polyurethane. They wouldn't make solid ones like SPL because they know a lot of people wouldn't spend the extra money or not mind the NVH (even though I have very little of over stock at this point.)
Old Sep 5, 2010 | 09:48 AM
itgogitrev's Avatar
Just hit 80k last night...
Andrei, what's your current setup? I saw your thread about the SPL comp bushings, looks like you did LCAs as well. Anything else done in the front, or anything in the back?
Old Sep 5, 2010 | 11:55 AM
obender66's Avatar
I ordered Whiteline bushings for spring bucket(inner is seized) and rear shock mount.
what NVH we should worry about with our loud exhaust systems, low profile tires, stereos and stiff as hell springs? Can it get ANY worse than it already is ?
Old Sep 5, 2010 | 07:34 PM
JaE35's Avatar
Moderator
G35 Sedan
My bushings are gone, i'm at about 120k...my front lowers to be exact. My whiteline bushings came in about two days ago, throwing them on in a few days will report back on performance
Old Sep 22, 2010 | 10:32 PM
JaE35's Avatar
Moderator
G35 Sedan
G drives like new with the bushings dropped in, i thought i needed new shocks but that was not the case. Night and day difference, especially turning. Car seems a bit higher in the front as well with the whitelines
Old Sep 23, 2010 | 01:47 AM
itgogitrev's Avatar
What all bushings did you replace?
Old Sep 23, 2010 | 07:56 AM
Dudefish's Avatar
Thanks for the update JaE35
Old Sep 24, 2010 | 12:59 AM
JaE35's Avatar
Moderator
G35 Sedan
just the two front lower, had all of the fore mentioned issues here...cracking sound, rough steering, and so on....all the aftermath of 20" rims
Old Sep 28, 2010 | 04:28 AM
sena's Avatar
when in doubt... all the above
Old Sep 28, 2010 | 12:58 PM
msommers's Avatar
How was the ride quality? Really bumpy/jittery or overall fairly smooth on road imperfections?
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
si_driver
Aug 11, 2015 07:08 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
