any1 have dba4000+halk pad?
Old Aug 27, 2010 | 07:05 PM
shksman's Avatar
any1 have dba4000+halk pad?-img_0145.jpgI put dba4000 brake rotor + halk pad about month ago.
I have no problem with it, but as you can see picture it starts get rust.
rear rotor is worth then front rotor
any1 has same problem???
what is best way to get rust out of rotor? it look ugly as hell~
Old Aug 27, 2010 | 07:13 PM
TurTLe*'s Avatar
that is normal. nothing u can do .
Old Aug 28, 2010 | 10:09 PM
shksman's Avatar
it seems my pad doesn't bite rotor all the way, is this normal?
any chance of made mistake while I was install?
can u post ur rotor pictures? so I can compare with mine
Old Sep 9, 2010 | 03:00 PM
cthrulies's Avatar
Yes. I have the same set up. I had the same problem. Solution = High Temperature Spray Paint in black. You can remove and paint only the rotors or leave everything assembled and spray the calipers & the rotor. If you don't have brembo's go ahead and spray the calipers, looks much better. Remove wheels. Clean your surfaces well. Wipe down with alcohol and spray 2 or 3 light coats. It does not matter if paint adheres to the swept portion of the rotor, your pads will sweep it clean. Done.
Old Sep 9, 2010 | 04:42 PM
jayk's Avatar
what are Halk pads? lol
Old Sep 10, 2010 | 12:06 PM
tonke73's Avatar
This is not normal but Hawk HPS are notorious for being pads with very poor initial bite. I had them on my car and hated them.
Old Sep 10, 2010 | 09:33 PM
Inspired's Avatar
^^x2 i had it and when they were warmed up ahh man it was horrible, i dunno i just hated it
Old Sep 11, 2010 | 10:31 AM
cthrulies's Avatar
Hawk ceramics + dba4000 = great for daily driver. DBA "tested" the combo on a WRX with good results. Also no dust, good stopping power. Maybe you should add steel lines as well.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
