Does this sound alright?
Old Oct 10, 2010 | 02:22 PM
ThickG's Avatar
I posted this in the coil/spring thread, but I didn't get a response so I figured I would try here.
I've never lowered a car before and I've done my research, but there is so much info out there that I just want to make sure I'm understanding everything. So, I was hoping you all could comment on the following setup for my coupe on OEM 19s.
I want to lower on 350z h-techs and will eventually do the spring mount mod. I'm gonna go with the SPC rear camber kit but will leave the fronts alone and will stick with the OEM shocks. Does this setup sound right?
I'm also gonna throw on 25/30 mm spacers. Do you all think I'll need to roll my fenders?
Old Oct 10, 2010 | 02:52 PM
xx7sephiroth7xx's Avatar
G
Sounds fine, I had pretty much the same setup for a while.
You will need to roll you fenders with those size spacers.
Old Oct 10, 2010 | 02:57 PM
Xet's Avatar
Xet
Yup that's fine. I ran the same setup but 25mm all around. You might as roll your rear fenders, it won't cost you even $100 and then you won't ever have to worry about it again.
Old Oct 10, 2010 | 03:04 PM
ThickG's Avatar
Thanks guys! Did you have any issues with running no front camber kit?
Also, how long should I let the springs settle before cutting the spring mount?
Old Oct 10, 2010 | 03:11 PM
jayk's Avatar
less than 1" drop with Tein H-techs should be fine without front camber kit.
springs settle 1-2 weeks.
Old Oct 10, 2010 | 04:48 PM
ThickG's Avatar
Great, thanks for the feedback guys!
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
