Suspension Squeak (Bushings & Endlinks Replaced)
Old Oct 15, 2010 | 10:31 PM
05AthensbluEG35's Avatar
I have a 2005 G35 with 68,000 miles; it drives like a dream except for one ungodly problem. My G has the same high pitched suspension squeak oft mentioned in your forums. When I am driving through the rough streets of San Francisco, my car squeaks like an old mattress after hitting the tiniest of potholes (Be the road level, or an incline/decline). To eliminate this problem I installed new end links from the dealership, and had new bushings from mynismo.com pressed into the front compression rods. To my chagrin, the god forsaken squeaking returned, keeping my car embarrassing to drive. My question is, could this squeaking be coming from the ball joint on the compression rods? Or does anyone have an idea where this could be coming from?
Old Oct 16, 2010 | 02:08 AM
The-Dream's Avatar
I'm thinking you need the revised compression rods.
Old Oct 16, 2010 | 02:13 AM
G35Papa's Avatar
It could be a number of things...two of which you just had replaced. I have the same squeaking noise right now but mine is the lower control arm, inner bushing. Another possible culprit could be the sway bar bushings. You should be able to give those a visual to see if they are torn/tearing/falling apart.
Old Oct 16, 2010 | 06:35 PM
Right on fellas, thanks for the help.
Old Dec 3, 2010 | 01:06 PM
SagiSRP's Avatar
did you ever fix your issue and find out what it was?
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
wuppiedog
Aug 7, 2015 11:16 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
