having trouble installing lower springs! Need Help
Old Nov 12, 2010 | 01:05 PM
thomas18a's Avatar
Recently, i purchased a set of Eibach Springs for my G35. I have no experience installing springs. The rear was easy. I finished it in half an hours. However, I am having trouble front the front. Those bolts were too tight. I tried with many different kind of oil, but didnt work. I lived in CA 91776.
who can help me to un-tight those bolts for me? thanks
it wont take long. please
Old Nov 12, 2010 | 01:26 PM
GreenGoblin's Avatar
The goblin resurrection
Impact gun or breaker bar.
Old Nov 12, 2010 | 01:34 PM
bjquinnIUmed's Avatar
^as stated. The right tools make all the difference in the world in a quick/painless install. Invest in an impact gun. Harbor Freight sells an electric one for about 50 bucks that works halfway decent. I used that on my suspension, and it's since come in handy on other jobs. If you're too cheap to go that route, at least have a can on PB blaster and a breaker bar. A thick, hollow metal rod that can slip over the end of your breaker bar to provide extra leverage for those extra tricky bolts helps as well.
Old Nov 12, 2010 | 01:52 PM
thomas18a's Avatar
I do have impact gun and breaker bar.I am trying to lose the bolts on the A-arm. I cant use the impact gun for there has not much space between that bolt and the suspension.
I tried with the breaker bar with Pb blaster as well. However, it did not work.
[img]https://g35driver.com/forums/members/g35cdriver-albums-front-suspension-write-up-picture12593-front-w-u-10.jpg[img]
Attached Thumbnails having trouble installing lower springs! Need Help-g35cdriver-albums-front-suspension-write-up-picture12593-front-w-u-10.jpg
Old Nov 12, 2010 | 01:54 PM
thomas18a's Avatar
Attached Thumbnails having trouble installing lower springs! Need Help-rtfr.jpg
Old Nov 12, 2010 | 02:12 PM
DrewLe's Avatar
You have a breaker bar, which makes a world of difference. Those a-arms are a pain in the a$$ though. Just get enough leverage and strength behind it to break it loose. If I can break it loose with a regular wrench, then your surely can do it with a breaker bar lol.
Old Nov 12, 2010 | 02:20 PM
onthe3rdday's Avatar
Why are you removing the A arms??
Old Nov 12, 2010 | 02:24 PM
DrewLe's Avatar
^You need to remove the A arms to be able to remove the front strut, thus changing the springs, which is what OP is doing lol
Old Nov 12, 2010 | 06:41 PM
Okay OP, now I see what you're talking about. I think I just used a 3/8" ratchet and then used a metal pipe to slide over the ratchet to get extra leverage on the bolt.
In case you happen to have one, the Harbor Freight blue racing jack has a 2 piece handle which happens to serve this purpose beautifully.
Old Nov 12, 2010 | 07:02 PM
FYI you do not need to remove the a-arms.
Old Nov 12, 2010 | 07:09 PM
DrewLe's Avatar
^Interesting...how do you manage to do that? I had to remove my A arms when I installed my Z suspension.
Old Nov 12, 2010 | 07:13 PM
IrockAG35's Avatar
Ohio G Club moderator
+1^^
the 2 circled in yellow need to be removed(breaker bar/PB blaster)..the 1 circled in red needs to be loosened and the whole control/a arm will drop down allowing u to remove the strut/spring
GAU-8's Avatar
I also have changed front springs without removing a-arms. gotta persuade it in and out but it can be done.
Old Nov 12, 2010 | 07:47 PM
DrewLe's Avatar
Wow that'll save me a lot of time the next time I work on my suspension. The diy I read from told me to remove the A arms. Thanks for the info, save OP some time too lol.
Old Nov 12, 2010 | 08:07 PM
IrockAG35's Avatar
NP..thats what the forum is for
