Sport vs non sport springs?
Old Dec 5, 2010 | 03:45 PM
plonka's Avatar
Okay, I have the 06 sport coupe. I am going to buy the Eibach Pro springs because I only want a mild drop. My understanding is that the oem sport springs are 1/2" shorter than the sedan springs, but are they 1/2" shorter than non sport coupes. If this is so, will the Eibach springs theoretically only drop my coupe 1/2" even though they are a 1" drop spring. I hope I didn't make this too hard to follow. Thanks!
Old Dec 6, 2010 | 08:55 AM
Bozo954's Avatar
PLONKA, you're good to go.
I have the same coupe with Tein 350Z H-Techs, and that's one of the few times you have to make those adjustments. In my case, add 1/2" to what it drops the Z.
But for you - using G35 spec'd springs - Eibach figures all that stuff our for us.
Just gotta make sure you or whomever orders the springs asks for the right vehicle/model application............or better still, model AND part #:
Check it out below - some of the data available from Eibach, stuff I had researched when deciding on my choice.
Part #s are slightly different, but different nonetheless:
Eibach Pro Kit Lowering Springs Infiniti G35 Coupe & Sedan Free Shipping
Model: G35, Sedan, 3.5L V6, Incl. S 6383.140 2007 to 2008..............G35, Coupe, 3.5L 6365.140 2003 to 2007..............G35, 4-door, RWD 6363.140 2002 to 2006
Description - Part # - Years - Front Drop / Rear Drop
G35, 4-door, RWD - 6363.140 - 2002 to 2006 - 1.1 in / 1.1 in
G35, Coupe, 3.5L - 6365.140 - 2003 to 2007 - 1.1 in / 1.0 in
G35, Sedan, 3.5LV6, Incl. S - 6383.140 - 2007 to 2008 - 1.4 in / 1.3 in
The Eibach Pro-kit dramatically improves both a vehicle's performance and appearance. The huge fender-well gap inherent from the factory or the installation of performance wheels and tires can give a vehicle a lifted look. The Pro-Kit is the perfect addition to any vehicle, lowering the fender gap and giving your ride a more attractive, sportier stance. By lowering the car's center of gravity, the Pro-Kit reduces squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus 1 or Plus 2 Size wheels and tires, the Eibach Pro-Kit is the finishing ingredient to a winning recipe for performance.
Excellent ride quality - comfortable in cruising
Sportive handling in cornering, resulting in improved performance
Lowered center of gravity, increased stability
Enhanced appearance of vehicle
Million mile warranty
Installation: Lowering kit installation is not terribly difficult. Remove the old shocks, springs, spindles, shackles, or other components and replace them with the new ones. That's it. (Don't forget to have a first class wheel alignment done when you are finished.) However, what will be required by the do-it-yourselfer is time and strength. The parts can be heavy. The procedures are sometimes awkward and require special tools. And the fasteners (nuts and bolts) may be very tight. Also, as with installing any new suspension component, you will typically find related parts that are worn and need replacing (i.e. tie-rod ends). To do a good job, be prepared to take your time, so while you are there, you can give the entire suspension/chassis a once over.
Last, but not least, when the job is done:
PIC-TURES...PIC-TURES...PIC-TURES...PIC-TURES!!
Don't be holdin out.
Old Dec 6, 2010 | 11:02 AM
plonka's Avatar
Bozo, that's just the response I was looking for. You're a good egg. I will be sure to post pictures. I've had my coupe for exactly a year and this will be my first mod. Can't believe I didn't start sooner.
Old Dec 6, 2010 | 11:57 AM
Bozo954's Avatar
Anytime, P. And hey, don't feel bad........I wondered the same thing, multiplied by 4.
You see, except for the 20" wheels, tinted windows, and smoked taillights - those ain't REAL mods in my book - I waited almost 4 years to even change my springs.
Got the car in Nov. 2006; just installed the springs in August 2010.
More to come, too; hopefully sooner rather than later, albeit modest upgrades in comparison to most.
Maybe a Seibon Carbon Fiber Hood; K&N Cold Air Intake and Air Filter.
Anyway, enjoy the Eibachs. Definitely a good choice, and I'd argue the 1st choice of reputable manufacturers that pops up in most cats' heads.
I've done Eibachs on my last 2 vehicles; no problems or complaints whatsoever.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
seagrasser
May 3, 2022 09:43 AM
Kelvin Style006
May 23, 2016 03:47 AM
bigmike
Sep 17, 2015 01:58 PM
spanky99l
Sep 7, 2015 12:46 AM
