Camber needed?
Camber needed?
My car just got lowered with 350z tein h and no spring mount mod. I have the oem 19" rays, oem tires and 20mm front/25mm rear spacers. Has someone run this configuration and got away with the OEM adjustability? Just wondering. And yes I SEARCHED
for 350z h techs, I actually needed a front camber kit and not a rear. But my oem suspension had about 60k miles on them prior to springs.
minor drop like that I doubt you'll need any camber kits. I can guarantee you the rear wont need a kit.
Camber
Just took my G35 coupe with 19" factory rims in for an alignment and they told me the camber was out of factory specs and that I had to buy the camber kit. They did supply the before and after settings and did not offer the kits (said they would install if I purchased them). After researching this issue, I beleive they are really needed.
In fact that is why I am searching for a camber arm kit today on this site that has been used successfully.
I've been looking for a set of these. It seems hit or miss about getting it back into spec but seems like this is the spring to get if you want to chance it without the kit. Its really strange, I've searched so many threads and theres no conclusive answer. Some get back into spec while others dont, it seems like it's just luck. I was looking into the Ichiba camber kit but they don't have an adjustable toe bolt? Also all toe bolts require you to dremel your subframe, which seems sketch to me.
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
