anyone have the whiteline rear subframe bushings?
Old Jan 11, 2011 | 12:26 AM
andrewstclair's Avatar
i had the white line rear sub-frame bushings installed and the differential bushings and it is making a clunking on hard shifts. is this normal from the stiffer bushings or should i look into it? does anyone else have them installed and does their do this noise?
Old Jan 11, 2011 | 02:38 AM
tyau's Avatar
It's not "normal", but it is common. Although it depends on the application, Whiteline typically uses a very hard urethane material on their bushings. Their bushings are usually a lot harder than Energy Suspension's.
Very common phenomenon is that the harder bushings is making gear lash more noticeable, therefore making pre-existing quiet clunking noises even louder.
Old Jan 11, 2011 | 02:45 AM
lol the gear mesh from the diff and the gear mesh from the trani and the rattle from the lightweight flywheel and vibration from the short shifter i have come to live with its a noisy car but the clunking i mean is when i shift hard it sounds liek it clunks like the subframe bushings have play in them almost more of a light banging as the subframe takes up the slack. it was made alot more noticable when i went to the heavier duty clutch
Old Jan 11, 2011 | 02:53 AM
Jairen's Avatar
Is the OEM rear diff bushing still intact?
Old Jan 11, 2011 | 03:01 AM
replaced with whiteline as well
Old Jan 11, 2011 | 03:02 AM
JBF's Avatar
JBF
I have SPL solid diff bushings and I never noticed any clunking. I would suggest checking torque on everything to make sure nothing is loose
Old Jan 18, 2011 | 10:36 PM
lsmooth81's Avatar
Did you installed the rear sub-frame bushings yourself? If so can you give me any pointers, thanks.
Old Jan 19, 2011 | 02:02 AM
tyau's Avatar
Make sure you have the strength to put it back before you drop it...
I personally met a a guy who dropped the diff, but was unable to put it back up and nobody was able to help him. Ended up taking the cab to work before someone was able to help him. The cost of cab was more than the installation.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
si_driver
Aug 11, 2015 07:08 AM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
