is this normal brake behavior?
Old Jan 13, 2011 | 02:51 PM
saywat?'s Avatar
idk if its related to weather or not but sometimes when the g is parked for hours and get in it before i start the car i naturally press on the brake. usually when i do it , it depresses but lately sometimes its stuck and i cant press it down until i start the car. jus wondering if its normal.
Old Jan 13, 2011 | 02:58 PM
Frankieg35's Avatar
Doesnt sound normal..
Old Jan 14, 2011 | 12:41 PM
dae's Avatar
dae
Does it only happen when the car sits in the cold overnight? If I let my car sit overnight in the cold, when I first get in the brake is "STUCK" and I cant push it down unless I pump the brake for about 1 minute. It then looses up and works like normal.
I was reading some other nissan forums and other people have experienced this too. There were suggestions to bleed all 4 brake lines because there could be air or moisture in the lines. There was also mention that it could possibly be the rubber vacuum hose going to the brake booster. I would bleed the lines first (I will be doing this soon) and if that doesn't work take it to a mechanic to look at the brake booster. But this is definitely not normal. I didnt realize my brakes werent working and I flew through a stop sign because the brakes did not work. Luckily nobody was around but it really scared me. I check the brakes to make sure they arent stuck before I drive anywhere now.
Old Jan 14, 2011 | 01:23 PM
saywat?'s Avatar
yea seems like it might have something to do with the weather cus it seems like it only happens when its cold or on rainy days. but once i start the car the brake works fine and normal. i jus figured its something similar to the afffect of when the cars off and u pump the brake pedal it slowly gets stiffer and stiffer till u cant depress it no more. still not normal?
Old Jan 14, 2011 | 02:30 PM
dae's Avatar
dae
Your issue is different than mine, but since the brakes work after you start up the car I think you are fine. As long as they arent getting stuck when you start up, I wouldnt worry about it.
Old Jan 14, 2011 | 02:32 PM
saywat?'s Avatar
^lol koo. thanks scared me for a bit there. yea as soon as i start the car the brake pedal depresses fine
Old Jan 17, 2011 | 05:20 PM
Mustang5L5's Avatar
It's a vacuum booster.
Try this. Start car. Turn car off. Pump the pedal a few times. It should get harder. This is normal as you purge vacuum from the booster. Now, put your foot on the pedal and press lightly and start the car. Pedal should sink. This is also normal.
Now, compare to when you notice the pedal is "stuck" and see if it feels the same. If itmis, then you are losing vacuum when the car is off...prob due to a leak. Check the brake booster check valve and replace grommet and valve if needed
Old Jan 18, 2011 | 03:20 PM
saywat?'s Avatar
^how do i check it? is this a visual thing? am i checking to see if the valve is tight?
Old Jan 18, 2011 | 07:25 PM
Mustang5L5's Avatar
Take some carb cleaner. Spray small bursts around the vacuum hoses in the area of the booster.
If the idle rises a bit, you have a vacuum leak. Make sure the grommet is not dried out and it's seated tightly. Check hoses for cracks. Might be a little more involved if you do have a leak.
It could also be somewhat normal for the booster to lose vacuum. I'll have tomcheck to see if mine has vac in the am.
Old Jan 18, 2011 | 07:27 PM
saywat?'s Avatar
^thanks
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
cmesidewayz
Sep 29, 2015 09:28 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
