Brake Advice: Rotor size
Jan 28, 2011 | 01:47 PM
Does anyone know cost effective options to increase my rotor size? I'm planning to get 19" wheels and I know they will look stupid with my tiny oem rotors.
Is there a way to fit larger rotors with stock calipers? If there is, what's the largest size that will look nice with 19" wheels?
This is for a non-brembo 03 g35 sedan btw.
Reply 0
Jan 28, 2011 | 07:22 PM
You can't run bigger rotors on the stock calipers. Your options are to go with the Brembos found on the earlier 6MT models (I believe 03-04), an aftermarket BBK, or dress up what you have.
I painted my calipers and bought cross drilled rotors. I'm not gonna lie, I bought the rotors for the look and not for any sort of performance gain. I have 6 spoke 19s with a lot of open space in the wheel and it looks pretty good. Here's a pic of a rear wheel, obviously the front rotor will be larger.
Reply 0
Jan 28, 2011 | 07:29 PM
if you want larger rotors w/o getting a BBK, OEM Brembos or Akebonos, then you might want to either look into upgrading to the full 05-06 OEM setup or the RacingBrace big rotor kits.
http://www.racingbrake.com/G35_s/3356.htm
Reply 0
Jan 28, 2011 | 07:46 PM
^^ this. I almost got a racing brake setup but I ended up going with the 06 Z non-brembo front/back setup.
Reply 0
Jan 29, 2011 | 02:00 AM
Quote: if you want larger rotors w/o getting a BBK, OEM Brembos or Akebonos, then you might want to either look into upgrading to the full 05-06 OEM setup or the RacingBrace big rotor kits.
Do you have any pictures of the RacingBrake on 19s? I can't find any and I'd like to see how big of a difference the rotors will look.
Reply 0
Jan 29, 2011 | 02:03 AM
Quote: ^^ this. I almost got a racing brake setup but I ended up going with the 06 Z non-brembo front/back setup.
how much did that cost you? Do you it's common to find this in my350z marketplace ?
Reply 0
Jan 29, 2011 | 02:07 AM
Quote: You can't run bigger rotors on the stock calipers. Your options are to go with the Brembos found on the earlier 6MT models (I believe 03-04), an aftermarket BBK, or dress up what you have.
Your rims loook amazing!!
I'm trying to stay away from bbk because they're so expensive. I'm not willing to drop more than 1k on brakes. (rather spend that money on the wheels )
Reply 0
Jan 29, 2011 | 09:17 AM
Quote: Do you have any pictures of the RacingBrake on 19s? I can't find any and I'd like to see how big of a difference the rotors will look.
Reply 0
Jan 29, 2011 | 10:37 AM
Thanks mang! There are a lot of chrome haters on here but if done tastefully they can look great IMO. Ignore the wrong tire sizes in this pic but it will give you an idea of how they look on the car.
This is how the car sits now.
Reply 0
Jan 30, 2011 | 12:26 AM
Very nice sedans boys, I'm jealous.
I guess they aren't going to be as bad as I thought. We'll see once I get the wheels.
Reply 0
Jan 30, 2011 | 12:29 AM
The Racingbrake setup comes with pads, rotors, and the extended bracket. To my understanding, it's the bracket that allows larger rotors am I correct? Do you know any vendors/websites that sell JUST the brackets?
Reply 0
Jan 30, 2011 | 04:55 AM
^nope
Reply 0
Jan 31, 2011 | 03:03 PM
Quote: how much did that cost you? Do you it's common to find this in my350z marketplace ?
$450 shipped for everything. (calipers, lines, rotors and pads) All in almost new condition. I upgraded to SS lines though.
The 05+ Z and coupes will have this setup also.
You could probably find it cheaper depending on condition etc.
Reply 0
