Brakes Squeal, only in reverse...
Old Mar 2, 2011 | 01:44 PM
NGreeeeeen's Avatar
Just got an '05 G35 coupe, noticed that my brakes squeal loudly ONLY when I'm backing up...Any ideas??
Old Dec 21, 2013 | 04:39 PM
dreloc's Avatar
Sorry to revive old thread but I'm having the same issue as the OP does and no answers at all. If anyone cares to provide input it's greatly appreciated. Thanks
Old Dec 21, 2013 | 07:36 PM
Urbanengineer's Avatar
Thanks for bumping, but it's part of having squeaky disc breaks.
Old Dec 21, 2013 | 11:36 PM
jookyshank's Avatar
I haz hugz to givez
Common issue with the G/Z factory pads, You can get aftermarket pads (I've had decent luck with EBC) to eliminate the squeal, at the cost of increased brake dust. YMMV
Old Dec 22, 2013 | 12:30 AM
Gooniej12's Avatar
Does it happen all the time or only when your brakes are cold? I had the same issue after I upgraded my brakes as in pads, calipers, and rotors. However, the squeak goes away once they warm up.
Old Dec 22, 2013 | 10:41 AM
Frankieg35's Avatar
My hawks do that when they are cold..
Old Dec 22, 2013 | 01:43 PM
Lartytiejdke3's Avatar
Lollll. thought Frankie had pet hawks til I kept reading....
Old Dec 22, 2013 | 10:15 PM
dreloc's Avatar
Yes only when it's cold & reversing. I just bought the car with 70K miles on it and seems like the PO hasn't change the brakes so I might upgrade with those Brakemotive kit & hopefully I don't get those dreadful squeal...it's so embarrassing sometimes
Old Dec 22, 2013 | 10:31 PM
Frankieg35's Avatar
I may be a falconer..
Old Sep 6, 2019 | 02:56 PM
Fletchaa24's Avatar
G35x awd sedan
Sorry to revive and old thread
This happens to me too. Only in reverse, something is making a loud squeal when I start to move whether I'm on or off the brakes. Pads and rotors are both fine and the ebrake is definitely not on. The solution that's worked for me a few times now is simply taking apart front and back brakes then giving everything a good clean then lube em back up...no more squealing. Again, sorry to revive an old thread but just in case anyone was wondering.
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
