Suspension Making Noise
Old Mar 2, 2011 | 07:12 PM
ytown87's Avatar
Ok I need some help. For the last 9 months my 04 6MT coupe has been making a noise (go figure with all the noises these make). But this isn't normal. My suspension makes the creeking sound like when you are walking through an old house and the wooden stairs and floor make that creeking noise. It does this at the beginning of acceleration and going over bumps. I have a warranty but I'm terrified of going to the stealership to have them check it out....don't want a $200 bill just for looking at it and finding out its something not covered by the warranty.
Anyone have any idea what it may be and if it is covered under bumper to bumper warranty?
car has 88k miles...sport kit brembo package...no suspension mods
if someone also would like to tell me about the chatter i have from the tranny when my the clutch pedal is depressed that would be great too. chatter goes away when pedal is pressed in. the suspension one is more important to me though.
thanks fellow G members
Old Mar 2, 2011 | 08:16 PM
TofuProductions's Avatar
Mine does that too, but then again my car has been through 2 winters so..
Lube it up with some wd40 haha, I'm kidding. Who knows, I just deal with it.
Old Mar 2, 2011 | 08:20 PM
WhosRich's Avatar
Just take it to the dealer and tell them the problem. They won't charge you for it. If they find something that isnt covered by warranty, they have to tell you before they start any work.
Old Mar 2, 2011 | 08:42 PM
EnerOnE's Avatar
You have to be more specific, where about is the creaking coming from? Inside the car/ outside/ passenger side/ etc, etc.
Old Mar 2, 2011 | 09:33 PM
wbama387's Avatar
The tranny noise is probably throw out bearing going bad.
Old Mar 2, 2011 | 09:37 PM
Strafe Automotive's Avatar
Could be the rear subframe or diff bushings. See if you have some leaks on the subframe mount..
Old Mar 2, 2011 | 10:27 PM
SharkG915's Avatar
I'm in the same boat as u but I hear the creaking sound when I turn the wheel I was thinking my rack n pinion(think thats how its spelled)
Old Mar 3, 2011 | 12:47 PM
I had the same noise until I went with new bushings. We can help you or another vendor to get these parts.
Old Mar 3, 2011 | 02:58 PM
RacerX35's Avatar
I was going to say to check the bushings also. I just replaced most of the bushings in the front suspension in the last few months and my G sounds better. I now have 120K miles on the car now, driving 70 miles a day round trip for work. I will need to replace that rear subframe bushing located in the center and waaayy up high on that frame. That will take some moaney as you have to completely remove all the suspension to remove that subframe. My G gets a clunky noise in the front still, but I believe that I need to check the strut mounts.
Good luck,
Ray
rezendvous420
May 31, 2020 01:26 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
itztwinki3
Oct 5, 2015 11:29 AM
atk08
Jul 30, 2015 03:12 PM
cyrus32
Jul 18, 2015 06:22 PM
