Springs for a Sedan with standard suspension
im not 100% sure but its something like that someone chime in please
If you have sporting intentions for you sedan, I strongly recommend getting the Z struts. They have quite a bit more dampening than the sedan Sport struts and make for more controlled handling. BUT be prepared for a stiffer ride, especially on pavement cuts.
The way I've dealt with the front inner tire feathering is to cross rotate the front tires (side to side) to knock down the feathered edge. I have to rotate every 2000 miles or so. It takes me about 15 minutes to do every 3 months so it's not a big deal. It still doesn't completely aleviate the annoying tire roar below 40mph as the tires wear.
? = 2B || !2B
Won't fix it. My G sedan, currently on Z/coupe springs, feathers the inner edges of the front tires regardless of the alignment setting. It's just something you'll have to live with if you drop the car an inch or more.
I need to throw my 17s back on and drive it and see if it changes :/
Crank your tires hard in on direction and run your hand across the inner portion of the tire clockwise. If the inner edge of the tire feels bumpy, scalloped, etc. and not completely smooth, then you've got the feathering problem.
A $500+ camber kit has been known to reduce or fix the problem, but it's my understanding that most of the issue is caused by an excessive caster angle and play in the bushings causing a toe issue, not camber. I never went with a camber kit because those are wrought with problems too like sheered bolts, camber that keeps falling out of range, etc.
I've just learned to live with it and cross rotate often. I still get 17K-20K miles out of sticky summer tires plus auto-x events thrown into the mix.
I'll remember to cross rotate the fronts in 3K miles, just recently rotated front to rear.
wow i was planning on buyin four new tires for my 19" rays but i think i might just get the fronts since one is flat and the other is on its way
i thought is was because i never got a alignment but now i think i might buy used tires lol ...i just want my car to look good guess i gotta pay
#30
