Pirates coilovers
Old Sep 2, 2012 | 06:24 PM
  #541
SuperTrooper699's Avatar
Hey guys got a question. I'm dropped pretty low on these coils. My lowest point of the car is 2.5inch. which would be ok if they were so damm soft. i'm about to rub threw my wheel wells. Now my front are on full stiff and they feel like they are on full soft. My preload is set at 10mm if i adjust it higher will that help stiffen up the ride or just make it more bouncy?
Old Sep 2, 2012 | 11:25 PM
  #542
mhmdmrk's Avatar
I also have a question about these coilover i had them on for about a month so far. The fronts are perfect but as for the rear I just instaleld the strut and spring without the pieces thats suppose to come with the spring.
Can anyone give me an explanation on how to install them, also I set the ride height by the strut/shock.
Old Sep 3, 2012 | 09:49 AM
  #543
JaE35's Avatar
Moderator
G35 Sedan
lol sounds about right, definitely give that a shot and report back for everyone else
Old Sep 3, 2012 | 10:18 AM
  #544
Your being serious? or do you know that adding more preload will make my ride really bouncy? 10mm of preload was kinda hard to get i'm sure i could twist that spring a bit tighter using the tools by hand. The only thing that i could see happening from this is, bouncier ride and maybe it would raise the car a 1\8th of a inch. Its dropped perfect in the front. once your so low its hard to raise your car haha
Old Sep 3, 2012 | 10:24 AM
  #545
Are you trying to install them true coil way or non? this video helped me out a lot when i first got coils. pretty much shows you how to do preload and turn the rears into true. "even though hes doing the front coils in this video"
Old Oct 22, 2012 | 06:19 PM
  #546
Anyone buy different springs for these coils to stiffen them up???????????
Old Jan 9, 2013 | 11:21 PM
  #547
How much preload are you guys running? I finally got my coils pretty dam stiff. I didn't switch springs but I'm running about 15-20mm of preload. I adjusted the coils where I had enough threads to do so, it's a lot stiffer now.
Old Feb 7, 2013 | 05:47 PM
  #548
toro12's Avatar
20 Year Member
"Ahoy Matees",
21 months on me pirates and me rates em' 4 ARRS out of 5.
"Yarr, Its been stated that I don't know what I'm doin'." harr, harr
The shame is the price increases on racingFirst EBay since I bought in Feb 2011 but still these are reliable, adjustable and simply can be "the catch o' the day."
They have done good thinks for me. My G sedan looks good, fun to drive and ride in.
Squiddys, if you don't have gold in yer wallets; Save money on these, they are respectable products for street rides. And, learn sport level suspension, wheel & tire fitment, camber, toe, alignment on your G.
Oh, me thinks the guns are a good idea if ya care to know!
"Arr, shut up. I know what I'm doin'."
Old Feb 7, 2013 | 06:48 PM
  #549
toro12's Avatar
20 Year Member
The "pirates" stance.
Old Feb 24, 2013 | 11:45 AM
  #550
916sgm's Avatar
Does anyone know what extenders will work for the rear, of any?...
Old Mar 19, 2013 | 09:38 PM
  #551
Hella_broke_G's Avatar
confused/help
Can anyone post pictures of the "true Style " on the rears a little confused how to install them btw i have topspeed coils
Old Mar 22, 2013 | 04:37 AM
  #552
izzueeek's Avatar
they dont have these on ebay anymore
Old Aug 19, 2020 | 01:05 PM
  #553
Skye35Sedan's Avatar
Auto, sedan, silver, slammed on eBay coils
I’m joining you.
[QUOTE=toro12;5735732]Arr, pirates, tis a scurvy scheme ere (to some on this forum) but it can earn ya a one way (oh and $520 cheap, was $450 when I pulled the trigger) reliable passage to DIY coilovers. Yarr
So squidy's yer "sticker shocked" and thinkin yer a "lost soul" and don't belong Narrr, Narrr.
As you be needin a "laugh" tonight read this:
https://g35driver.com/forums/brakes-...coils-get.html
Now, here is a report and some follow-up,
alas matee's "no private shame"
Attachment 241627
Attachment 241628
Attachment 241629
'fer now let us batten down the missenmast, Matees.'
Enjoy this report.
I'm the 1st to admit rolling with these $450, G350 coilovers on this forum, I think.
Maybe someone else has them but I'll take the "sword" for being truthful about it.[/QUOTE
I recently installed that exact same set of coil overs on my sedan. I noticed a metal clicking noise from both rear control arms, immediately when driving it on the coils. I used the oem lower rubber mount for the lowering spring on both rear control arms. I made sure I used all the rubber mounts that came with them, but I’m still hearing noises. This is after I double checked everything to make sure it was torqued to spec. The only thing I’m wondering, is the lack of rubber mounting causing these noises? The only way to fix that would be cut the oem spring to the same length as the rear lowering spring, and then take the lowering spring out and out the oem rubber mounts and cut Oem spring on both rear control arms. Well still having the lowering strut on both rears. Do u experience these noises from the control arms?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
