Passenger front clunking noise - 2004 Infiniti G35
Old Mar 16, 2011 | 09:21 PM
psc72879's Avatar
I have a 2004 G35x with 75K miles. I have noticed when I'm driving and hit bumps in the road there is a clunking noise. I put the car on the lift and it seems that there is a little evidence that there is leakage coming from the shock. Any ideas? thanks
Old Mar 17, 2011 | 12:34 AM
04G35NYC's Avatar
Compression Roads need to be changed i have the same problem on both sides are done for ripped up.
Old Mar 17, 2011 | 02:15 AM
psc72879's Avatar
Thanks.......I am actually pretty handy.....is the compression rods a dealer only item only? Is it pretty easy to change? Would I have to have the front end aligned after swapping out? I might as well change both sides? thanks
Old Mar 18, 2011 | 06:12 PM
RacerX35's Avatar
I just replaced mine, but still have a noise coming out like the front end is loose or something. I've replaced all the bushings in the front end. I ordered my parts from mynismo.com. I only bought the compresion rod bushings, not the whole rod and they cost $25.00 each.
Old Mar 18, 2011 | 06:22 PM
MikeDG's Avatar
Did you do your swaybar endlinks when you replaced the bushings? If not, might wanna check those.
Old Nov 15, 2011 | 04:49 PM
nkhan's Avatar
I have similar problem on my 2004 G35X, I changed Sway bar links, bushing, compression rod bushing, shock absorber with insulator and rubber seal etc but looks like nothing working. It still have cliking sound when hit a small bump.
Blakelyg35
Jul 21, 2015 12:49 PM
vstypicals
Jul 20, 2015 10:55 PM
cyrus32
Jul 18, 2015 06:22 PM
wylin
Lights
Jul 18, 2015 06:12 PM
