Front Suspension Noise
Old Mar 16, 2011 | 10:54 PM
guesswho?'s Avatar
Hello, everyone! I did some researching but did not find what I needed. My front suspension on my 03 coupe with about 94k miles is very rough over bumps and does not feel smooth like factory. Before the noise occurred I had on Skunk2 lowering springs that was about a 2.5 in drop. Once I removed the lowering springs and placed on the OEM springs again, this started to happen.
Well here's my question. What do you think is wrong with it?
I've seen some say that it can be a compression rod bushing, new struts, strut mounts.
I'm on a budget right now and I don't want to spend money on something that wont fix it. I'm highly sure that its the struts.
I was thinking about getting the Tokico blue front struts since i heard that it was equilvalent to oem.
What do you think I should get to fix it?
Also, I went to sears auto here in the midwest and they evaluated my car and said that my struts are bad and I need strut mounts. I just wanted to make sure on here if anyone else had a similar problem. Thank you very much!
Old Mar 18, 2011 | 06:08 PM
RacerX35's Avatar
I think I've been running into the same problem. I've had the stocks on the whole time and after 100,000 miles, I am getting a noise like that also. My mechanic said that he believes it to be the mounts or shackles <(something like that). When I go over bumps, it sounds like the front end is loose. I am getting a set of coil overs now and hopefully that works. I am sure if I replaced for another set of stocks, that would fix it too. I just justified getting new suspension and my nephew has a shop to do the work for me too, to cut cost.
Later,
Ray
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
jimNC
Jul 25, 2015 05:47 AM
cyrus32
Jul 18, 2015 06:22 PM
