Help!! Bad rubbing problem!
Old Mar 24, 2011 | 03:25 PM
Buju On Friday's Avatar
I just dropped on 350z H&R sport springs and as they have settled this week I am having the same problem. I am on 20x8.5 +20 and 245/35/20. I already have my front fenders rolled, but I am still rubbing a little bit on the fender. I am also rubbing on the front of the wheel well where the bumper is mounted, so can you explain more how you fixed it?
I think I am going to have my fenders pulled some and hope that helps, but I will still have the rubbing on the front of the wheel well. I didn't want to have to go to a 30 series or a narrower tire really, so if there is another fix that would be great.
Old Mar 24, 2011 | 06:59 PM
Dranom's Avatar
^shocks might be nearing the end of its life and tires are too tall.
When you pull the fenders your wheels will tuck more
Old Mar 24, 2011 | 08:22 PM
Xet's Avatar
Xet
Stiffen up your struts unless you are running stock struts... What camber are you running too?
Old Mar 24, 2011 | 08:56 PM
stock struts. I need to get a-arms, so my alignment is out right now. I think I am about 1deg too negative. But won't running less negative camber only make my problem worse?
Old Mar 24, 2011 | 10:40 PM
Dranom's Avatar
Front camber arms wont do you any good
Shocks are too soft thats why the tires are eating the fender liner
Also trim the metal piece that holds the fender and bumper. Youll see it sticking out when you peel the fender liner
Old Mar 25, 2011 | 11:18 AM
Ok thanks guys. I'll try trimming that this weekend
Old Apr 8, 2011 | 01:42 AM
MTG35guy's Avatar
Sorry I didn't see this thread was still going. I bent the bumper bracket up and backwards. QUick fix until i can do a little grinding. I also smoothed down the part my bumper that was sticking out as well. Let me know if you need more info.
pigpen infiniti
Aug 16, 2015 09:07 PM
saskicker32
Aug 11, 2015 02:12 PM
Tylerttn
Aug 10, 2015 07:13 AM
Soumilg
Jul 18, 2015 12:33 PM
