need BBK help/advice!!
hey everyone so its time to upgrade my brake set-up for my 03.5 sedan with 17 inch sport rims. ive been trying to find a set of calipers and rotors for my car but dont really know what or where to look. i have around $1000 and was wondering if thats enough for a nice set of rotors and brakes. Please help!
-Dylan
-Dylan
The first thing you are going to have to do is upgrade your wheels. Most BBK's for the G35s can only accomodate a 18 inch or larger aftermarket wheel. Once you have a BBK the spare/OEM tire option is out the door. If you have wheels already and you are looking to spend 1k your bet bet would be a set of used Brembo's from a coupe or 350z.
i agree with hi-techg35.. you need to find wheels that will clear bbks then choose bbk.. for 1,000 you wont find much.. i got the akebono kit and it was like 1900 and well worth it
Buy aftermarket rotors, pads and stainless steel lines it will be a huge improvement over stock. Unless you just want a BBK for looks in that case the money would be better spent on aftermarket wheels.
[QUOTE=Sylvan lake V35;5805197]Buy aftermarket rotors, pads and stainless steel lines it will be a huge improvement over stock. Unless you just want a BBK for looks in that case the money would be better spent on aftermarket wheels.[/QUOTE
Well the reason I want them is because my back calipers are shot so I need buy new ones anyways. I'd be happy with oem coupes but idk if they'll fit my 17s
Probably the only choice with the standard 17s
https://g35driver.com/forums/brakes-...-z-brakes.html
They fit under my non-sport 17s but barely.
seagrasser
May 3, 2022 09:43 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
