Grind noise while turning right
Old Apr 30, 2011 | 03:29 PM
JBz007's Avatar
I have an 05 5AT Coupe and every time I turn to the right, hard or soft, I hear and feel grinding. It almost sounds as if it is coming from inside the steering wheel. When I turn left it acts normal. I recently installed headers and had to disconnect the drive line to put them in. Do you think that has anything to do with it? Thanks for your help.
Old May 4, 2011 | 10:55 AM
JBz007's Avatar
Bump. Need some help.
Old Aug 29, 2011 | 10:53 AM
JBz007's Avatar
Solved. Steering rod is slightly touching the header causing a slight grinding while turning right.
Old Mar 2, 2012 | 08:16 PM
Mystroe99's Avatar
hey i'm having the same problem with my 05 coupe as well. I noticed it today with the radio off. I wouldn't say it sounds like grinding noise, but more like a deep squeak if that makes sense?
any thoughts?
Old Feb 22, 2015 | 11:19 PM
kchar92's Avatar
I have the same problem
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
magnetism80
Feb 1, 2019 10:00 AM
mattdg35
Sep 14, 2015 11:28 AM
NJ6MT
Sep 10, 2015 08:40 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
