Compression Rod bushings - pics
Old May 16, 2011 | 11:00 PM
JacekPSUr6's Avatar
The cracks aren't really visible, but if you were to look at the bushings when the car is on the ground, you'd most likely see the busted bushing under all the pressure that is put on them. If the creaking noise is there, just replace the bushings. All I could really see when I took the compression rods off were some tiny creases. Both of the sides were making noise, and by replacing them both, all the creaking noise has gone away.
Old May 17, 2011 | 09:28 PM
MikeDG's Avatar
Originally Posted by JacekPSUr6
The press finally came in and I was able to complete the job. If you're thinking of doing it yourself, get a bigger press than 6 tons because the one I got was too short - not enough of a clearance to fit the pieces in there. I was able to break the rubber part through, then press the ring out - I used that ring to push the 2nd bushing out with ease. I wasn't able to fit all the pieces in to press in the new bushings and I decided to give up pay a local Midas shop to get the new oem bushings pressed in - $25 cash did the job and it was well worth it. I tested the car and the creaking is gone - I just hope it will not come back and I'll have to do this all over again. If for some reason I'll have to replace them again in the near future, I already have the press and will buy polyurethane bushings as replacements. I'm super stoked that it's fixed and I didn't have to replace anything else. I also had the car re-aligned since I lowered it a few months ago. Next job will be to replace my rocker/valve covers, which are leaking oil through the busted seals. I have all the parts, just need to get to it.
All in all, I'd say it's worth to do it yourself - I spent about $185 in parts and Midas labor to get the whole job done
Good to hear you got the CR bushings in. Sorry, I forgot to mention that I had to "mod" the Harbour Freight press to get everything to clear. I took the bottom legs off and lowered the cross brace to give me the extra few inches needed.
Good luck with the valve cover install. Are you using oem covers or the R&D Factory seals?
Old May 17, 2011 | 09:58 PM
JacekPSUr6's Avatar
^ not a problem at all. It did the job for the most part I'm using the R&D factory seals - bought the whole kit, just need to get to it.
Old May 17, 2011 | 10:12 PM
GAU-8's Avatar
I meant that there looks to be a crack in the metal going from the bushing hole out towards the rod.
Old May 17, 2011 | 10:15 PM
JacekPSUr6's Avatar
^ oh my bad, no it's not a crack - kinda looks that way on the pic, but that rod is just fine.
Old May 17, 2011 | 10:17 PM
GAU-8's Avatar
Cracks are circled.
Old May 17, 2011 | 10:18 PM
GAU-8's Avatar
Sorry, I was looking at the pics and marking them as you replied. So are those scratches or something? The appear to radiate from the ring out.
Old May 20, 2011 | 05:10 PM
EvoBeast's Avatar
those definitely look like cracks
Old May 20, 2011 | 05:15 PM
VincenzG35's Avatar
Originally Posted by lox1985
My dealer said the same thing. I took a chance and swapped the bushings but it did not help my issue. I'm thinking of replacing entire rod at this point. My bushings did not look worn at all. I replaced them with OEM bushings (the part # you provided is the one I got).
Lower control arms do the same thing noise wise so if it didn't help check those bushings
Jessica Ayoub
Oct 17, 2015 02:01 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
TheBay
Sep 3, 2015 03:27 PM
