Will adding spacers make "feathering" worse??
Old May 5, 2011 | 09:40 AM
Manny2ksi's Avatar
I have a slight drop with 350z H's and im on OEM 19's with 245/35 & 275/35.
I am changing tires every 20-24k and im about to get my 5th set and just wondering if adding 20mm spacers all the way around will make things worse.
im debating on speding $500 on a camber kit but right now thats the price of the rear tires....
suggestions??
Old May 5, 2011 | 12:00 PM
Deezflip's Avatar
I don't think it does, if your toe angle was, let's say .05°...it'll still be .05° but just further out. Your best bet is a wheel alignment but you could still end up with feathering...just not as quickly.
Old May 5, 2011 | 12:08 PM
G35Buzz's Avatar
Hey, to my understanding spacers do not affect alignment ... So your tire wear should remain the same but the stance will look better
Old May 5, 2011 | 02:30 PM
4D05G35's Avatar
Spacers will just widen your track and they wont change your alignment specs.
Old May 5, 2011 | 03:25 PM
irishsig's Avatar
As mentioned before it won't make a noticeable diff in feathering.
25mm all around looks better.
Old May 6, 2011 | 04:15 AM
Xet's Avatar
Xet
20-25k miles isn't bad for our cars, I would be happy if I were you!
Old May 6, 2011 | 09:05 AM
Manny2ksi's Avatar
it is when you do 25k a year and have to buy tires every 10-13 months.
Old May 10, 2011 | 02:03 PM
FenixL1P's Avatar
^ that takes a hurting to the wallet when you gotta save or budget for new set of tires that often... I felt that with my previous set... the current set is lasting longer so i'm feeling more relieved... as for the spacers affecting alignment, when it is aligned to specs it shouldn't be affected that much... but once it starts to go out of spec, it'll be amplified i think... my geometry is a little rusty.
Old May 10, 2011 | 02:05 PM
4DGS's Avatar
Buy a new car....
Old May 10, 2011 | 08:43 PM
Blue Dream's Avatar
I drove ttrank's car solo
Think how much you would have saved if you had just bought the camber kits from the beginning.
Xfactor
Dec 1, 2019 12:52 PM
Phenomenon9
Aug 9, 2015 01:34 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
