Problem after BC Racing and SPC kit install
Old May 29, 2011 | 12:24 AM
hamzafraj's Avatar
Exclamation Problem after BC Racing and SPC kit install
Today, I have installed BC coilovers and SPC kit; the install went smoothly until I test drove the car.
Now both VDC and Slip lights are ON. Not only that but also the car does not move forward when foot off the brake, feels as if something is pulling against it, so gotta accelerate for it to move. I don't hear any clicking and I don't know what is going on?
Old May 29, 2011 | 12:28 AM
herrschaft's Avatar
Where the shims installed, and if so where the spacers installed behind the sensors on the front wheels?
Not sure about that.
Old May 29, 2011 | 01:02 AM
bigc's Avatar
Wings Nation
did you install a front and rear SPC kit, or just the rear? if you did the front, verify that you have the correct gap between the ABS sensor and the back of the bearing hub.
also, if you installed a front kit, double check that the shims are installed in the correct orientation. if you put them upside down, the brake caliper and rotor will be misaligned.
Old May 29, 2011 | 01:29 AM
hamzafraj's Avatar
can't sleep of worry but will check first thing in the mornin
Old May 29, 2011 | 04:49 AM
Xet's Avatar
Xet
check your shims and abs sensor positioning. it's tough to get it installed correctly, I didn't even bother putting my shims on and my camber isn't too bad without them.
Old May 29, 2011 | 07:09 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you only have the the SLIP and VDC lights on and NOT the ABS light then it's an alignment problem. Your rear camber/toe is probably so far out that the wheels are working against eachother, not allowing the car to roll smoothly.
Old May 31, 2011 | 09:21 AM
05Scoobyroo's Avatar
^^ +2 If you don't hear any noises, your alignment is most likely that far out of whack!
Old May 31, 2011 | 09:32 AM
g35man04's Avatar
CLUB MODERATOR
any pics of before and after? def check the shims......you dont have the ebrake on do you?? just checking...doesnt hurt to ask.
I have installed many coilovers and yet to have a problem like this after being installed..the shim kits from the SPC's I have never installed either which makes me think thats the issue
Old Jun 1, 2011 | 10:26 PM
hamzafraj's Avatar
Problem solved!!! It was the spacers/shims which I placed upside down. Pfiuu, what a relief... Thnks guys for all da help, appreciate it!!
Old Jun 1, 2011 | 10:34 PM
hamzafraj's Avatar
Smile
Some pics after da drop
Attached Thumbnails Problem after BC Racing and SPC kit install-img_0489.jpg   Problem after BC Racing and SPC kit install-img_0491.jpg   Problem after BC Racing and SPC kit install-img_0496.jpg   Problem after BC Racing and SPC kit install-img_0497.jpg   Problem after BC Racing and SPC kit install-img_0499.jpg
Old Jun 1, 2011 | 11:25 PM
herrschaft's Avatar
FYI - If you ever upgrade to a BBK you may have to remove the shims for it to work properly.
Old Jun 1, 2011 | 11:58 PM
bigc's Avatar
Wings Nation
First I've heard of that. I have a BBK and still run the shims.
Old Jun 2, 2011 | 12:11 AM
herrschaft's Avatar
^Odd, I had to remove the shims for my RacingBrake setup to install properly.
Old Jun 3, 2011 | 12:14 AM
bigc's Avatar
Wings Nation
yeah, very weird. the shims didn't create any issues for my old rotoras or my current brembos
Old Jun 3, 2011 | 07:35 PM
hamzafraj's Avatar
Well my next few mods would be wheel spacers prolly 20mm front and 35mm in the rear (any brand recommandation since we're at it?), sway bars then a set of Akebono
