BC Racing rear suspension question
Old Jul 17, 2011 | 05:57 PM
fatlip's Avatar
A shop installed my set and I noticed yesterday that the coil is upside down as compared to the pics ive seen here. The fat part is on the top and the gold lock collars are on the bottom. Also if i disconnect the shock and let the rear suspension hang freely the shock is about 1.5 inches short and I have to jack up the arm in order to get it to reach. Does this sound right???
Old Jul 17, 2011 | 06:11 PM
Xet's Avatar
Xet
First part, by what you describe no it's wrong.
Second part sounds like they were trying to set the droop, you should have to jack up the spring cup to get the strut to align with the hole. But, usually it shouldn't be 1.5" I believe.
edit: https://g35driver.com/forums/v36-diy...r-install.html follow that
Old Jul 17, 2011 | 09:36 PM
fatlip's Avatar
Thanks man. What kinda problems could running it like this cause?
Old Jul 17, 2011 | 10:32 PM
Xet's Avatar
Xet
Who knows. The perch part is supposed to be on top, and isn't designed to take the impact the way it would on the bottom. This could be no big deal, or it may cause it to break eventually. As far as the pre-load being off, your ride could be setup much more efficiently and would be more beneficial to you.
Take it back into the shop and show them how it should be done, they should fix it since they made the mistake...
Old Jul 18, 2011 | 05:15 AM
fatlip's Avatar
This is where they got the install info. Its for a G37 but scroll down to the rear section pics and u can see the coil is inverted.
http://www.nicoclub.com/archives/pro...n-part-ii.html
rezendvous420
May 31, 2020 01:26 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
