Grinding noise coming from left rear brakes
Old Jul 20, 2011 | 12:58 AM
Affalterbach's Avatar
This started out of nowhere sometime 2 months ago. I did nothing to the brakes nor removed the wheels at all until now. I took the wheel off 2 days ago to visually inspect everything and everything looked good, it seems that the pads are at about 50%
What happens is I hear a grinding/scratching sound at low speeds when "lightly" getting on the brakes or when coming to a stop from 35-40mph. Anything faster than that and I have to step on the brakes harder so I don't hear anything.
Here are 2 short videos I took at a parking lot, one is just cruising around it, the other video is driving down a street from 30mph to 0mph.
and at a parking lot, it almost sounds like some sort of spring, this is at low speeds moving around parking lots
Old Jul 22, 2011 | 05:20 AM
bueler? bueler?
Old May 18, 2012 | 10:03 PM
cowboys13's Avatar
Hey im having the same problem! Did you ever fix it ??
Old May 19, 2012 | 02:58 AM
Invalid_User's Avatar
loose lug nuts
Old May 19, 2012 | 03:08 AM
cowboys13's Avatar
No that cant be the problem. Ive had tires put on, new brake pads, brakes lubed, ive even taken off the wheels myself and im pretty sure the shops and i have tightened those lug nuts pretty tight.
Old May 19, 2012 | 10:43 AM
Tunerz_Store's Avatar
Wheel bearing going out allowing movement in the wheel.
Old May 19, 2012 | 12:11 PM
cowboys13's Avatar
Replaced that yesterday, noise still there.
Old May 19, 2012 | 01:33 PM
Warped rotors?
Old May 19, 2012 | 03:47 PM
joedaddy1's Avatar
this sounds dumb but maybe bent dust shields rubbing on your rotors?
JUST a guess.. you can try bending it or just trimming it out..
Old May 19, 2012 | 03:48 PM
Herbbie Hablib's Avatar
Does the noise change when you play around with the e-brake while rolling?
Rotors rubbing dust shield?
Old May 19, 2012 | 06:05 PM
cowboys13's Avatar
Never thought of bent dust shields or playing around with the e-brake. Ill check that out, thanks guys appreciate it.
Old Jun 24, 2012 | 06:50 PM
cowboys13's Avatar
Anybody else?? Noise is still there!
Old Jun 24, 2012 | 10:38 PM
I never resolved the issue but Ill check out the dust shields and just re lube everything
Old Jun 25, 2012 | 12:18 PM
MarkG's Avatar
I vote for a dust shield rubbing on the rotor. Pull the wheel off and spin the rotor. I had a small rock stuck in a caliper once, but you've had it apart enough to rule that out.
Old Jun 25, 2012 | 04:32 PM
cowboys13's Avatar
I doubt it.. if it was the dust shield dont you think it would be a constant rubbing not just when we're baking and coming to a stop..
