Question about parts and bushings.
I am STILL experiencing looseness and extra vibrations in the front, especially when driving over cracks or rough patches. I'm thinking my lower control arm (or bushing) needs to be replaced because the right wheel has a mind of its own when hitting bumps by not tracking straight and overcoming the rough patch like it should. Most of the vibrations are felt through the gas pedal.
Well Originally I changed my control arm bushings for Whiteline lower control arm bushings and I also changed the compression rod bushings for SPL bushings. I also ordered some megan inner tie rods as well and Timken front hub and bearing sets to see if that stops the vibration at higher speeds. I would need to change my wheels as well and check the engine mounts for wear. As well I need to have someone build bushings for my camber kit so I do not have to toss it. Just replace the bushings. Alot of stuff to try and avoid high speed vibration and uneven wear... My car is slightly dropped due to the eibach racing street usable springs. Running on 19" forged volks.
joedaddy1
07-28-2015 02:58 PM
BlueBelleG35x
07-23-2015 02:10 PM
