Post your alignment specs with the drop
Old Aug 17, 2011 | 08:29 AM
lox1985's Avatar
Hey all,
I'm trying to see what everyone is running with what drops for alignment spec.
Here is my spec sheet with about 3 inch drop:
The goal is for me to see if I can get closer to spec.
Thanks
Old Aug 17, 2011 | 09:47 AM
Pepper's Avatar
Toe = within spec
Caster = within spec
Camber = -3.50 F & -3.75 R
Old Aug 17, 2011 | 01:37 PM
eurodre's Avatar
toe and caster in spec
camber -3.5/-5.5
Old Aug 17, 2011 | 01:47 PM
danielv12's Avatar
i don't know exactly how much of a drop I have but,
toe = 0 front and back
camber front = -3
camber rear = -3.5
Old Aug 17, 2011 | 01:48 PM
Frankieg35's Avatar
I think my next set I'm gonna run stock alignment settings and no fender work.. my rear fender lip is grinded smooth.. just sit flush..
Old Aug 17, 2011 | 02:22 PM
4D05G35's Avatar
At the time of my last alignment I was lowered about 1.5" front and rear.
Front:
Camber 2.1
Toe: .08
Rear:
Camber 2.2
Toe .13
Im now a little lower so my settings are probably out of spec, but ill be returning soon to get that checked/adjusted.
Old Aug 17, 2011 | 02:35 PM
zoop425's Avatar
dropped around 2-3 inches and here is my sheet (no camber kit yet)
Old Aug 17, 2011 | 08:39 PM
lox1985's Avatar
Does anyone who has their toe in spec and dropped couple of inches with -3 degree camber, how did you do it?
Old Aug 17, 2011 | 09:24 PM
eurodre's Avatar
a camber kit and toe bolts...
Old Aug 17, 2011 | 09:26 PM
lox1985's Avatar
Got both...need to install my spc toe bolts but I got camber kit in there.
Old Aug 17, 2011 | 09:52 PM
eurodre's Avatar
so get an alignment before asking questions of how to get toe in stock spec
Old Aug 17, 2011 | 11:44 PM
Xet's Avatar
Xet
That's your problem. Get your toe bolt in, make sure you extended the hole and you should easily be able to get toe in spec.
Old Aug 18, 2011 | 08:17 AM
lox1985's Avatar
will do. Thanks all. Just wanted to see if it is possible.
Old Aug 20, 2011 | 12:07 PM
lox1985's Avatar
Well, I got the SPC toe bolts installed and had an alignment done. Toe is back in spec. Thanks everyone for sharing your specifications.
Soumilg
Jul 18, 2015 12:33 PM
