stance GR+ oem type height adjustment help!
Old Sep 1, 2011 | 03:45 AM
laksjd84's Avatar
hi, i have oem type stance GR+
how do i go about adjusting my oem rear setup?
i adjust both spring in the bucket and strut at the same time right? how do I know how much adjustment on strut is equal to adjustment on spring (since diameter is different)?
ex. 1 full turn on strut = .5 turn on spring..etc..
Thanks!!
Old Sep 1, 2011 | 09:43 AM
Algy's Avatar
with my coils for the spring bucket. i just wanted the drop similar to my h-tech drop so i made the shock body length as oem but a tad bit shorter. you want to do it to the height of the drop.
Old Sep 2, 2011 | 03:34 AM
laksjd84's Avatar
what?
Old Sep 2, 2011 | 04:34 AM
Frankieg35's Avatar
Take the strut out.. adjust the height of the car with just the spring.. measure from the top of the strut mount to the bottom where is mounts on the car.. then take that measurement and adjust your strut..
Old Sep 2, 2011 | 04:38 AM
Frankieg35's Avatar
U prolly could leave the strut in but I took it out so I knew for sure it was done right..
Old Sep 2, 2011 | 01:00 PM
laksjd84's Avatar
u mentioned nothing about adjusting spring in the bucket...
Old Sep 2, 2011 | 01:07 PM
G35Papa's Avatar
IIRC one full turn on the spring collar adjustment = one full turn on the strut. So they are equal.
Old Sep 2, 2011 | 02:59 PM
laksjd84's Avatar
oh wow, good to know papa.
so if they are euqal like that, it should be pretty simple to adjust height.
does the spring need to come off the bucket to adjust collar?
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
