**Air Management Install **Accuair VU4 and Non leveling remote
Old Sep 8, 2011 | 10:38 AM
1lowG35's Avatar
**more pics will be added, this is only the beginning**
Greetings,
Originally I had the full UAS kit however, it constantly leaked which was due to the **** poor install that was done. After two fires, constant leaks, and blowed compressors. I decided it was time for a change. After reading the reviews of air management systems, I decided to go with one of the best. I ordered the Accuair Vu4 and non leveling remote system.
This box contains all the old valves and lines that came from the UAS kit. Four valves were in the front bumper and four were located in the trunk.
Never have I seen my trunk so clean. It was cluttered with the valves and wiring from the last failed install. Even spider-man couldn't find his way out of that web! (i'll update those pics later)
Here have the mounting board with the compressor,vu4 block, the ecu, and all necessary components. I have one more compressor coming in. I'm using vivair 480s(which have been blowing out like all holy hell).
The Accuair VU4 requires 3/8 lines for the install. My first install used 1/2 lines and good god was it ran horrid. No zip ties were used to hold the lines to the body so it would not shift. #FAIL Zeb @ I/S/O did a excellent job with EXTRA attention to detail and constantly kept my safety in mind. All lines were ran inside of the car instead of through the fender wells (unlike that 1st install).
Here is the remote controller for the VU4. The 1>2>3 are for the adjustable burst speed of the air release into the bags. No more sudden burst of height like my car was kicked in the a$$ by a horse. Just one smooth fluid motion.
I can't thank I/S/O (Insane Stance and Offsets) for their help and support while my car was DEAD due to the failed first install. Special thanks to Zeb M and Steve N from my crew ISO and Jeremy and Chet of the Body Shop in NC.
Old Sep 8, 2011 | 01:34 PM
SN00P's Avatar
CLUB MODERATOR
Awesome man !!! looks so much cleaner !!!
Old Sep 8, 2011 | 01:41 PM
1lowG35's Avatar
Appreciate it SNOOP!
Old Sep 8, 2011 | 01:44 PM
1lowG35's Avatar
I really need to log into my OG account lol......
Old Sep 8, 2011 | 02:12 PM
LordFappington's Avatar
glws, the VU4 is a god send for anyone getting bagged. Cleans up your install tremendously and no 400 different parts for each solenoid are needed.
Old Sep 9, 2011 | 01:15 PM
1lowG35's Avatar
You can say that again brother!
Old Sep 9, 2011 | 02:02 PM
Antoniog35's Avatar
Were can u buy this system and any pics of car ?
Old Sep 9, 2011 | 06:32 PM
1lowG35's Avatar
You can buy the system from ACCUAIR or even on ebay. Pics of my car are at this article
http://www.airsociety.net/2011/07/dirty-gee/
Old Sep 9, 2011 | 07:59 PM
labguy94's Avatar
Congrats on the new setup. I saw this over at airsociety. How does the ACCUAIR non-e-leveling system work? Is it by pressure alone?
Old Sep 9, 2011 | 08:46 PM
1lowG35's Avatar
That is a very good question. From what I've read and seen it operates on the same principle of valves. It works of pressure. If i got the e-leveling system then it would level the vehicle out but I was not going to pay a extra 800 dollars for it. Eventually I will put the gauges back in but we are not finished with the build yet.
Old Sep 9, 2011 | 09:40 PM
labguy94's Avatar
Thanks for the info. I'm really interested in the Accuair e-Level system but it is $$$... Keep up the good work on your build.
Old Sep 12, 2011 | 11:09 PM
DrewTheSuit's Avatar
any reason you didn't go with their exo mount?
Old Sep 15, 2011 | 03:00 PM
1lowG35's Avatar
I can get someone to fab it for much cheaper lol.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
JMSABO
Aug 4, 2015 11:58 AM
Texasscout
Jul 24, 2015 03:43 PM
