installing LCA bushing
Old Oct 20, 2011 | 12:29 PM
whoisthis's Avatar
that's how I tried. you actually have to push down toward the ground in order to loosen the stud head. this would not allow me to use full force I was kinda afraid that I would strip something if I use the breaker bar on the head stud instead of the nut
ima grab a longer breaker bar from autozone
Old Oct 23, 2011 | 11:09 PM
whoisthis's Avatar
with the autozone's long **** breaker bar, i was able to get it off
i installed the bushings on the passenger side which took like 5 hours lol.gotta do the driver's side tomorrow.
There's a 1~2mm gap between the inner bushing and the Lower control arm. Will this be ok? or do i have to take off everything and use the press to get rid of the gap?
The squeeking noise that i had when braking is now almost gone. i still here it sometimes. i forgot to lub the frame that makes contact with the bushing
Also, since i have 05, there are two "bump" on the inside of the frame. i trimmed it but i couldn't get them to completely flat out.
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
erickLA
Aug 18, 2015 04:46 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
