hitting arm on bumps?
Old Oct 12, 2011 | 04:28 PM
DPE_G35's Avatar
sup fellas,
im slammed all around with 10.5 rims with an agressive fitment, but im keep hitting something on bumps looks like an arm on the front wheel well, what can i do? do i need more spacers and camber?
Old Oct 12, 2011 | 04:45 PM
g35844's Avatar
if its the front tire thats hitting, you can pull out ur fender or more camber...if its the arm, i had that problem and i trimmed the plastic liner around the camber arm in the wheel well, problem was solved...
Old Oct 12, 2011 | 05:19 PM
beezy619's Avatar
Sub'd for answers. I have this issue too.
Old Oct 12, 2011 | 05:55 PM
Xet's Avatar
Xet
what arm? the camber arm?
Old Oct 13, 2011 | 12:48 AM
DPE_G35's Avatar
i honestly dont know, which arm but i do know for a fact what ever it hits, it curbed my rim from the inner side.
Old Oct 13, 2011 | 01:38 AM
Algy's Avatar
I think I know what you are referring too.
Its like when you drive at normal speeds and you see a bump coming up.. once your front end comes in contact with that bump and the car reacts to it, you get this loud knock/clunk noise right?
I have the same issue as well as my other friend with the same coilover setup. The think though is that I have SPC A arms while his our stock.. I have no idea what the sound is either but I know that I got the sound after installing the arms and lowering the car.
I remember reading a thread about this stating it was the upper control arm (A arm) hitting the upper wheel fender in the inside.
Old Dec 13, 2011 | 02:21 PM
DPE_G35's Avatar
hey fellas, im still having trouble any ideas how to slove this issue?
Old Dec 13, 2011 | 10:08 PM
Xet's Avatar
Xet
if you have spc front camber kit, it is known to "clunk" if you have them then run a search and there is plenty of topics on the issue.
Old Dec 14, 2011 | 02:40 PM
DPE_G35's Avatar
yeah i just have the stock arms, no aftermarket
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
jilljann1
Jul 21, 2020 08:12 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
bigmike
Sep 17, 2015 01:58 PM
