Wheel Studs
Old Oct 24, 2011 | 11:57 AM
GGRJR's Avatar
Wheel Studs
While chcnging out my rear brake pads last night, I found that the tire place managed to cross thread a lug nut last time they were rotated. The only way to get teh wheel off was to break it. Still waiting on a call back from them. In the mean time what is involved with replacing teh studs? I only got a quick look at it last night, I was so disgusted I didn't want to look at it. Looks like teh brake rotor may need to come off, is this teh case?
Old Oct 24, 2011 | 12:14 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Yes, pull the brake rotor off. You gotta tap out the broken stud and then pull / tighten in the new stud.
Old Oct 24, 2011 | 12:17 PM
GGRJR's Avatar
That is what I was afraid of. When I pulled the original rotors, I had to pretty much destroy them, get them off.
Old Oct 24, 2011 | 12:19 PM
Sylvan lake V35's Avatar
I did one years ago, I don't think I even needed to take the rotor off if I recall right. If you spin it and look at the back there is a spot where you can get at it from the back. I then pounded the broken one out. I pounded the new one most of the way then used a lug nut with some washers and an impact gun to suck it the rest of the way through.
Old Oct 26, 2011 | 10:23 PM
wompem's Avatar
I think there's a DIY video running around showing how to do it.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
si_driver
Jul 14, 2015 12:29 PM
