camber kit needed when lowering car?
Old Nov 14, 2011 | 06:09 PM
kr33p's Avatar
hey guys, im wondering that if when i lower my car using the tein s-techs on my g35 sedan 2003, if i will need a camber kit?
i know lowering it will give me some camber and camber wear on the tires, but how much life is expected out of my tires if i dont use a camber kit?
and if anyone is running this set up without a camber kit as well.
thanks in advance.
Old Nov 14, 2011 | 06:34 PM
rozhenko's Avatar
I just installed a front and rear camber kit today. I've been running on stock camber arms for 6 months on eibach springs. The inside of the tire went bad after 3 months. Then I went to shop so they can take the tires off the rim and flip them the other way so I drove 3 more months on those tires. Now I got a camber kit and new tires. If u decide to get a camber kit, don't buy cheap ones like godspeed or kinetix because a lot of people say they bent or brake while u drive.
Old Nov 14, 2011 | 11:36 PM
prinny's Avatar
Camber kits are a must the majority of the time even if you don't lower your car much at all. The main reason for buying GOOD camber kits is mainly because the off brand or cheaper ones don't provide you with enough positive or negative adjustment. Those camber kits aren't cheap either.. which is why the springs that I got for cheap a couple months ago are still sitting in corner in my garage.
If you don't use a camber kit.. don't expect your tires to last long at all.
Old Nov 16, 2011 | 01:55 PM
Naveed2126's Avatar
Can you post a link to the front and rear camber kits you've install on your car? Also, yours is a first gen. sedan?
Old Nov 16, 2011 | 02:07 PM
rozhenko's Avatar
It's a coupe. I'll get the pix up today
Old Nov 16, 2011 | 02:12 PM
Naveed2126's Avatar
I don't need to see pics of your car. If you can just post a link to the camber kit you purchased. Thanks.
Old Nov 16, 2011 | 02:14 PM
rozhenko's Avatar
Here is SPC rear that i got. I got confused at first cuz i thought it was for 2 arms but that price is for one. And SPC is really good quality.
http://www.ebay.com/itm/SPC-Performa...sories&vxp=mtr
And heres the eibach front camber arms i got.
http://www.ebay.com/itm/Pro-Alignmen...sories&vxp=mtr
They all fit coupes and sedans
Old Nov 16, 2011 | 02:22 PM
Naveed2126's Avatar
I'm at the point where I'm debating if I should get the rear camber arms all together, one for each side. I'm not slammed, but I'm dropped about 1.3" Front and 1.1" Rear. I think I can get away with just the elongated toe bolts in the rear and nothing in the front. My alignment before/ after shows that I'm out of spec by less that 2 degrees. I really just need adjustment ability for upto +/- 2.0* degrees. I think these: http://www.z1motorsports.com/350_g35...oducts_id=4637 will work for the rear, but now I need something comparable for the front. Any suggestions?
Old Nov 16, 2011 | 02:28 PM
rozhenko's Avatar
Well ull know later on when u see how ur tires are wearing out.
Old Nov 16, 2011 | 02:34 PM
Naveed2126's Avatar
I've actually been lowered for over 3 years now, but recently, I went maybe .25" lower all around. I've never had premature or uneven tire wear. In fact, I'm still on the same set of tires for 3+ years now. I'm more concerned about this time around, being that I'm a tad lower, and would possibly like to avoid uneven wear in the future. Hence, I'm simply looking for elongated toe bolts to try out for now and go from there.
Old Nov 16, 2011 | 03:05 PM
irishsig's Avatar
SPCs are really good and they come with the toe bolts so you can get back into spec.
Out of spec toe can wear tires quicker than neg camber.
Jusseth
Sep 13, 2020 12:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
