E-Brake Lights, VDC OFF, & SLIP Lights All On
Old Dec 9, 2011 | 08:37 AM
dealaddict1231's Avatar
Hi,
I got into an accident with my car about a month ago, I broke the right control arm. I replaced the control arm, and when the job was done my VDC, SLIP, And ABS lights were on. I realized that the service tech did not put the ABS sensor back into position. I put it in myself and everything went away. But now I have a different problem.
In the mornings when I go to work, I drive for like 2 minutes and the E-Brake, VDC off, and Slip light all come on, then after another 5 minutes of driving the E-Brake light goes away, and only VDC and Slip lights are on. But, if I turn off my car and drive after a couple hours it drives normal for the rest of the day.
This only happens to me during my first drive of the day. Unsure of what the problem is, been to Infiniti, they diagnosed it, but couldnt figure out the exact problem. I am willing to spend the money, but Infiniti wont ensure that fixing the issue would actally result in the problem dissapperaring. Any Suggestion, I have search the forum but no one has a similiar issue.
Help would be really appreciated, also anyone know any good Infiniti mechanics in the Toronto area, eastern Toronto, Pickering area.
Old Dec 11, 2011 | 02:43 AM
CoolaidG35's Avatar
lights on dash
i had the same problem with my G coupe it was my rear tires one was more bald than the other. i believe that caused my ecu to think that i was lossing control with one tire doing a faster rotation then the other. My VDC light would come on along with my slip and brake light, only in the morning or after i had the car sitting for a long period. The brake light would go off after a while, so i got to new tires in the rear and it fixed the problem...
Old Dec 11, 2011 | 08:23 AM
0MGHI2U's Avatar
Check ur abs fuse. That's wat happened when I got rear ended.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
