Hotchkis sway bar question... also, which settings?
Old Jan 3, 2012 | 11:03 PM
Nightm4re's Avatar
I am ordering up a set of used Hotchkis sways and i had a few questions.... Besides the metal bar, so i need anything else to make them work or will they fit perfectly with the stock components? (those rubber (bushing?) things)
Also, i have an 06 coupe with the sport suspension package, i was curious what the best settings were to run, without getting too much oversteer/understeeer compared to stock. (if anything, i can deal with a little bit more oversteer though)
Old Oct 11, 2012 | 02:26 AM
kristinavq's Avatar
did you ever figure out the best setting and if the stock bushings worked ??
Old Oct 11, 2012 | 10:37 PM
Herbbie Hablib's Avatar
Full-stiff front, full soft rear, Ive tried every combo and i like this the best just like they recommend. if your lowered get after market links too.
Old Oct 12, 2012 | 02:59 PM
kristinavq's Avatar
i thought if you did full stiff front youll get more understeer ??
jsimonk
Dec 22, 2023 03:49 PM
Sepsis
Feb 12, 2020 02:05 PM
zoop425
Mar 29, 2016 05:51 PM
linedr89
Aug 17, 2015 05:11 PM
TreeFiddy
Aug 10, 2015 06:50 PM
