Rattling after rear suspension install? I have a pretty simple solution
Old Jan 8, 2012 | 06:58 PM
c_morse's Avatar
You guys are going to think I'm nuts. I still half way don't believe that this worked for me.
I recently installed a set of KW Variant 1 coil overs and immediately noticed a lot of rattling coming from the rear of the car.
I read KW's install directions, and noticed a step where they said to install "foam isolator" in the rear. Well I didn't have that (not sure if they come with the kit new or not).
Anyway, I went to my local Michael's and picked up a couple sheets of 1 inch upholstery foam. Very easy to cut and stuff into places.
I jacked up the rear of the car, removed the wheels, and took out the struts. You'll notice a small square cavity above the struts. Probably 6 inches square and 3 to 4 inches tall. I cut 3 total 6 inch squares for each side and stuffed them one at a time through the mooting hole for the strut. After all three were in, there wasn't much if any space left.
I reinstalled the struts and went for a drive.
A good majority of the previous rattles and noise were gone! I really still don't believe it, but it worked well!
Total cost? $10.
I'm a happy camper and just wanted to share this with y'all in hopes that it'll help you as well!
Old Jan 8, 2012 | 07:43 PM
ShanesG's Avatar
That's weird, shouldn't have to do that. Make sure the top bolt of the actual strut is tight. If loose will cause ALOT of rattling/clnking.
Old Jan 8, 2012 | 10:38 PM
COOP IV's Avatar
I have the same rattling problem from the rear after installing my f&f coilovers .
Old Jan 8, 2012 | 11:46 PM
c_morse's Avatar
I read and read on this and it seems a lot of people have this problem even after checking the top nut and such. Just a phantom rattle that can't be traced.
FWIW I don't necessarily think it's coming from the struts per se, but for some reason the little bit of sound deadening in those spots did help. I figured it was worth a try if KW's install instructions even had a step for it.
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
kinetek
Aug 3, 2015 04:25 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
