Group Buy: GTspec Fender Reinforcement Brace
Old Jun 1, 2012 | 08:50 AM
  #256
Boog's Avatar
I'm thinking the threaded insert goes here (only picture i could find):
Old Jun 1, 2012 | 09:14 AM
  #257
sexyrob's Avatar
yes, it goes in that hole.. you are basically crushing the threaded piece in there by using an impact driver.
so first you will put down the flat washer that has a seat in it for the threaded piece that goes in to the hole, then you thread in the screw, then put the "spacer" on, then the washer, and finally the nut.. put a wrench on the "spacer" and then take you impact and I think its a 19mm and just crank on it (forward motion)
you have to do this carefully, if you don't keep pressure on it, it will start spinning which is what you absolutely don't want to happen. if it starts spinning you will need to find a way to rip it out and use the spare they gave you.
Old Jun 1, 2012 | 12:16 PM
  #258
OldManRivers's Avatar
still able to get a set of these?
Old Jun 1, 2012 | 12:22 PM
  #259
Ray@OCInfiniti's Avatar
Joker170 :
YES! I have two sets left ready to ship!
please call me at 714 650 8586 ext 158
Old Jun 2, 2012 | 04:58 PM
  #260
suprasam's Avatar
sooooo is anyones holes on the frame bigger than the threaded piece? I should have taken pictures but I was frustrated with some other projects and put everything back together.
Old Jun 5, 2012 | 05:04 PM
  #261
Boog's Avatar
I don't really understand. Are you saying the holes have a smaller diameter than the threaded inserts? It wouldn't really surprise me if we have to drill out the holes to match the insert size, but I didn't get a change to install last weekend to know if its needed.
Old Jun 5, 2012 | 05:18 PM
  #262
suprasam's Avatar
^^Boog Reverse that. The holes on the fender frame of my car are a larger diameter that the insert parts. I try to "crush" one in but it has room to jiggle about. It has nothing to grab onto.
Maybe I misunderstood Sexyrob's instructions.
I will get measurements this weekend.
easy analogy- the insert has the diameter of a penny, but my frame hole has the diameter of a nickel.
Old Jun 6, 2012 | 12:06 AM
  #263
2one8's Avatar
I havent started to install these yet, but why do we need to use the hardware supplied with the braces? Is it possible to just use a bolt, washer, and nut?
Old Jun 6, 2012 | 06:23 AM
  #264
suprasam's Avatar
^^i didnt see a way to get a nut behind the hole. But once others look at it they may help with other ideas.
Old Jun 6, 2012 | 08:34 AM
  #265
05 sedan's Avatar
How much is the demo set
Old Jun 6, 2012 | 09:44 AM
  #266
sexyrob's Avatar
there is no way to get a nut behind the hole unless you chop up the unibody.
Old Jun 6, 2012 | 10:18 AM
  #267
suprasam's Avatar
yea that is what i saw. i will get measurements and send them to tony. maybe the gtspec guys can come up with a larger diameter thread piece
Old Jun 6, 2012 | 11:51 AM
  #268
sexyrob's Avatar
that is weird...
please let us know a few things about your car
year:
sedan,coupe:
auto,manual:
could anyone have touched your car before you? for example, I had done a wiretuck and used the holes to run wires through, is it possible someone else did this on yours and maybe reamed the holes out some?
Old Jun 6, 2012 | 12:04 PM
  #269
suprasam's Avatar
I have an 05 coupe 6mt. I've had it since new so no one has messed with the hole. I did a wire tuck myself bit didnt mess with the frame.
Old Jun 6, 2012 | 06:57 PM
  #270
So does anyone with a sedan want to try their hand at these?
