Suspension noise
Old Feb 11, 2012 | 02:51 AM
Nortex's Avatar
Suspension noise
I swapped over to the coupe front and rear struts-springs and all with about 40 k on them and after a day or so they started making a creeking noise when turned over bumps. Backing out of my driveway is steep and when you go to turn it creeks from the front. It doesnt do it when your sitting still and turning the wheel. What could theis be. Im guessing compresion rods but I dont know where they are? Also when doing the swap should I have put weight on the car before tightning anything down?
Old Feb 13, 2012 | 11:27 AM
HYDRUS's Avatar
Same problem with my coupe on z stechs. When i switch over i kept my stock shocks cuz i couldnt afford them and plan to get some tokico blues but its been a while and still havent gotten around to it so the new height and stock shock not used to it will start to wear down way earlier than intended so all you need is new shocks.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
