The "perfect springs" - lots of research done
Old Feb 16, 2012 | 12:13 PM
WataG's Avatar
Alright fellas, I've been trying to decide on the "perfect springs" to lower my 03 coupe with for the last couple months and have narrowed it down between the following:
-350z Tein S-Techs (drop of 1.1"F and 1"R) Spring rates in LBS 386/402 (estimated front intial rate is 327lbs). Cost $175.
-350z Eibach Pro Kit (drop of 1.5" F&R) Progressive spring rates in LBS initial/final front 296/384 initial/final rear 316/421. Cost $225.
I really can't decide between the two. These will be going on stock shocks, and I have oem 18's. Might roll on oem 19's soon, aftermarket wheels later on. I already have a SPC rear camber kit and toe bolts. I won't be putting too many miles on the car, but I do go over 10 good sized speed bumps a day. Not really concerned about driveways...haha. I have a N1 front lip as well. I want that "lowered look" but I want to be able to drive at the same time. I'm thinking the eibach will be a smoother ride, which I'd like (since it's already kinda bumpy), correct me if I'm wrong.
Suggestions/comments welcome, appreciate it!
Old Feb 16, 2012 | 12:22 PM
dofu's Avatar
20 Year Member
http://www.swiftsprings.net/
Old Feb 17, 2012 | 02:41 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
save up some $$$ and change the shocks when you do your springs. do not pay for the labor twice as your stock stocks will not be good for long.
then get some decent linear rate springs like RS*R Ti2000 for 350Z, Hotchkis for 350Z, Tokico D-Spec for 350Z or the Swift Sport for 350Z as mentioned above.
Old Feb 20, 2012 | 12:38 AM
WataG's Avatar
Thanks for the info.
Not concerned about labor costs at all, my buddy is a mechanic and we can swap them out quickly. I put some OEM 19" rays on today and the car rides a whole lot smoother than with the stock 18s. The tires on the stock 18s just seemed like super hard rubber for some reason w/ 35psi. So now I'm pretty sure the shocks are fine.
Will I be able to get over speed bumps without too much trouble dropped 1.5" all around? I want to go lower than the Tein I think, just want to make sure I'm good w/ speed bumps and the progressive springs not being bumpy or bottoming out, etc.
Old Feb 20, 2012 | 08:02 AM
EL-EE-ES's Avatar
Im on swift sport spring for the 350z, love them...the car is lowered but not slammed. i have speed bumps at work an clear them fine as will as a steep driveway at home that takes a slight angle to clear. I have the N1 lip and impul sideshirts
Old Feb 20, 2012 | 08:24 AM
DRG35R's Avatar
20 Year Member
any pics available...did your rear drop? sorry to highjack.
Old Feb 20, 2012 | 08:25 AM
DRG35R's Avatar
20 Year Member
would be interested in an answer here since I am considering the Tokico D-Spec springs for the 350Z which should drop 1.5F and 1.5R. my car is not a daily driver though.
Old Feb 20, 2012 | 08:32 AM
EL-EE-ES's Avatar
forgot to say im on 350z tokico d-specs
Old Feb 20, 2012 | 01:51 PM
jstudrawa's Avatar
Not sure if I can bring myself to go with progressive, tho the Eibach range is much tighter than most.
Talking to a guy at S&R Performance, he said the Eibach Pro Kit is something I'd be really happy with.
So on the fence again
Old Feb 21, 2012 | 05:29 AM
DRG35R's Avatar
20 Year Member
that is the stance I have been looking for. that looks perfect. thank you for the pics. your car is very nice and clean. love the wheels.
Old Feb 21, 2012 | 08:36 AM
jarvo's Avatar
Which shocks/struts would be best on 350z Tein S-Techs?
Old Feb 21, 2012 | 09:00 AM
EL-EE-ES's Avatar
I would go with tokico d-specs...very popular with people who run springs
Old Feb 21, 2012 | 09:01 PM
DRG35R's Avatar
20 Year Member
would you mind posting your wheel/tire specs. do you rub at all in rear? did you have fenders rolled? did you do the spring mount mod? thanks.
Old Feb 21, 2012 | 11:36 PM
EL-EE-ES's Avatar
19x9.5+20 255/30
19x10.5+20 285/30
I wasn't rubbing at first, but got a camber kit and alignment now I have a slight rub on the rear
Fenders will get a slight roll next month
No spring mount mod
Old Feb 22, 2012 | 05:48 AM
DRG35R's Avatar
20 Year Member
19x9.5+20 255/30
19x10.5+20 285/30
No spring mount mod
I run similar setup 19x9.5, +19 245-35 and 19x10.5, +19 275-35 and I am on 350Z D-spec shocks and 350Z RSR Ti2000 springs with SPC camber kits front and rear, but my car looks jacked up compared to yours. can't believe your back end dropped that much with the Swift as they are supposed to be the same 1.1 drop as the RSR. I still have a full 2 finger gap in rear. I am thinking of going with the Tokico D-Spec 350Z springs as they are supposed to have more of a drop, but I can not find anyone running these on a G coupe for advice. the drop looks right on a Z, but have not seen them on a G coupe.
