BC Racing BR series coilover question
#32
I think I will try it. If its too stiff I can order new ones and sell these. Thanks, I been wondering if I could do. One more question, is that 2.5 diameter spring.
#34
#38
I just checked with BC, they would have to be ordered. There really isn't much of a cost difference from me to you, so you can just order directly from them if you want the swifts.
Just remember to go 2k lower than what you were running already. so if you had a 8k setup, 6k will be almost exactly the same feel.
The other thing i have discovered is you won't be slamming the rear of the car with this setup, so I'm working on correcting that issue so going lower is feasible although, I wouldn't go much lower than I'm at now except 1/8'-1/4".
#39
#40
#41
True Coilover setup now available...
BC Racing True Rear Coilover
Lowest this setup will go.. 275/35/18 tire 25 5/8" from ground to fender.
#42
#43
#44
My BCs don't have a hard ride but I would say that the small bump absorption does suffer... probably a product of the damping and perhaps the use of aluminum vs steel? My kit came with a ~1" gold spacer that I use on the rear and I have no problem adjusting ride height within an inch of stock.
I have an '05x too, I'm going to buy these this spring and I'm just trying to get all the info before I purchase them in May.
#45
I have the premium package with the reclining rear seats so I just attached the extenders to the top of the dampers and they stick up behind the seats for easy adjustment.
Carrera57 (03-14-2013)
