Anyone tried this for adjusting front camber?
Old Mar 5, 2012 | 07:07 PM
OBsessed's Avatar
I was just wondering if anyone has tried / thought of the following for adjusting their front camber ...
I'm low enough that even when the front is jacked up I can't get a wrench, much less a socket / ratchet on the nut on top of the upper A arm (SPC Front Camber Arms) to adjust the camber. I have to take the suspension half apart to drop it down far enough to loosen that to adjust it.
What I'm thinking is - What if I drilled a 1/2" or 3/4" hole through the engine bay over that nut (just big enough to get a ratchet extension through)? I can turn the wheel far enough to reach up and put a socket on top of that nut, but I can't get a ratchet to it as is.
I'm sure that part of the body serves some structural rigidity purpose, but would a small hole make much of a difference? Upside if doable is that I could dial in my own approximate camber without completely dismantling the suspension.
Thoughts?
Old Mar 5, 2012 | 07:15 PM
Frankieg35's Avatar
It is a pain but u gotta think is it worth it.. Cause after your car is aligned how many times do u mess with it..
Old Mar 8, 2012 | 11:54 PM
TougeMonsterG35's Avatar
that would work without being a big deal and you could just get those black flat plugs....
do it!
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
cbax
Aug 17, 2015 07:41 AM
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
