left rear scraping
Old Apr 21, 2012 | 01:49 AM
eodg35's Avatar
left rear scraping
Hi all i am lowered equally on both sides of my car and have 25mm spacers in the rear, i recently installed my SPC camber arms and toe bolts and now my driver side scrapes my fender when i turn hard right. It doesnt scrape on the passenger side if i do the opposite. I just got my alignment done as well and that didnt help, any suggestions would be helpful. As of right now all i can think to do is raise that side more and get the car aligned again. thanks in advance
Old Apr 21, 2012 | 10:16 AM
SuperCleanG's Avatar
Take it back and get it re-aligned. Depending on the shops machine they might not be able to get it all the way dialed in. If that is the case jsut do find someone to roll or pull the fender
Old Apr 21, 2012 | 10:30 AM
eodg35's Avatar
they got me back in to specs. i just find it odd because it didnt do it at all before the camber arm install
Old Apr 21, 2012 | 10:40 AM
Yup.. ur gonna have to roll or pull.. this is not uncommon.. What offset are you running?
Old Apr 21, 2012 | 10:49 AM
eodg35's Avatar
i have the oem 18's with 25 mm spacers. So whatever that is.
if you dont mind me asking where are you out of in MN, im from austin.
Old Apr 21, 2012 | 11:29 AM
Im not sure about 18's offsets.. I had oem Rays with 25mm spacers dropped and didnt have issues.
Im out in the Twin cities.
Old Apr 21, 2012 | 11:32 AM
eodg35's Avatar
yea i had no issues until i did the camber arms and toe bolts. ill just mess with the height and camber and try to make it not do it, its not to severe
Old Apr 21, 2012 | 11:43 AM
G35SedanGrn's Avatar
your offsets are 18x8 +5 with the spacers just so you know.
Old Apr 23, 2012 | 07:51 PM
eodg35's Avatar
raised my left rear some as the rear was unever, still getting scraping. how much neg camber could i run without to much wear
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
