SPC A arm Ball Joint
Old Apr 27, 2012 | 02:41 PM
sacpbyee's Avatar
So i purchased the SPC A arm to fix my negative camber for my front wheels. The ball joint on it keeps going out and making a horrible squeaking noise. This my third ball joint i went through. Anyone else have this problem?
Old May 10, 2015 | 09:51 PM
rob.cal's Avatar
Reviving an old thread but I do how did you fix it
Old May 10, 2015 | 10:17 PM
sacpbyee's Avatar
I didnt do anything but raise the ride height a bit. I think i had it to low and the stress was just too much.
Old May 10, 2015 | 10:27 PM
rob.cal's Avatar
What's your setup I'm only on 350z h techs so only a slight drop
Old May 11, 2015 | 03:00 AM
sacpbyee's Avatar
Im on BC coilovers. Here is an old pic so you can see my ride height.
Old May 11, 2015 | 03:02 AM
rob.cal's Avatar
Sweet ride. Hmm I'm nowhere near that low. Dang sucks wonder if I just have to live with the squeaks
Old May 11, 2015 | 03:09 AM
sacpbyee's Avatar
Are you 100 % positive that the squeaks are coming from that ball joint?
Old May 11, 2015 | 03:12 AM
rob.cal's Avatar
Fairly sure. Was there once before lubed it and it went away. Stored the car for winter and now it's back. Thought about the compression rod but I don't think that's it
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AL8782
Oct 3, 2015 10:26 AM
Jeff T
Sep 30, 2015 02:00 PM
