SPC rear camber arm toe bolt problem
Old May 25, 2012 | 01:18 PM
ReStylin's Avatar
So I was just doing some work putting my new exhaust on, when I noticed that the previous owner put on SPC rear camber arms, with the toe bolts... and he ended up drilling (Elongating) the Rear camber arm inside mounts, rather then the bucket mount for the toe bolts...
Where can I get the stock bolts to go in the rear camber arm.... also does it make a difference that its been widened?
Old May 26, 2012 | 10:26 AM
Theory_EK's Avatar
Its really nothing to worry about you can just put the stock bolt in tighten it down and adjust camber on from the arm. Its not going to matter that it is elongated. I am sure if you put a WTB ad in the for sale section someone will come forward but if I were you I would just buy some new toe bolts and install them in the correct spot.
Old May 26, 2012 | 07:31 PM
ReStylin's Avatar
I got some stock bolts today from a friend who was parting out a G.
lol, swapped everything over today, it was actually a pretty big difference.
EPG35
Aug 16, 2015 04:52 PM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
