Coilovers Vs. Springs?
I just got a 06 g35 6mt about a month ago. I was just wondering what I should go for.
Also what is a good brand of both of them. I will say I don't like the way that the slammed hondas bounce when they go over a pot hole I don't want to slam it but I want it be lower. If you have pics of yours one coils feel free to post them.
I think it really depends on your needs. A good set of quality springs and shocks will perform well and ride comfortably, but they will be "fixed" in terms of the actual ride height. Coilovers offer a wider range of adjustment, so if you see yourself lowering your car more and more in the future that might be the way to go. Through the many car forums I browse, I have found that this is the case for many (including myself). You drop the car a little bit, then later on you go a little lower, a little lower, and then soon enough you'll find that you're slammed haha.
Prices will vary quite a bit though. Do you have a specific budget you'd like to stick with?
- DD, so not looking to go too low or drive too aggressively. No track.
- Price limit 1k, but lower the better.
Also, couple extra questions. What parts do the coil overs replace, Shocks/Spring/Struts? On some used ones I see that they need to be rebuilt. What's the price per coil over and the avg time/or mileage before it needs a rebuild?
How does yours ride. I just don't want to lose all of the comfort. Also do you have any pictures of it? I will have this car for a while I just broke 40k miles. I have always been into the suv seen and I want to make this car look hella good.
It depends if yo are going for comfort, performance, adjustability, or looks.
If you want adjustability and looks, go with coils. The ride will not be close to comfortable, and while your car will feel fast through turns, it really isn't unless you are putting a whole lot more work and money in to make that happen. The mid priced (2-3k) coilovers perform ok at best. As for the cheap ones, don't expect much at all. You might be better off with the pricier set-ups, but we're talking 4-5k range here, but I know from experience that not all of them are that good either.
A good spring and strut combo will be comfortable as it will be better balanced and better matched to your car. And because it's better balanced, it will perform better, but it's not going to slam your car to the ground.
![JAMIN](https://g35driver.com/forums/images/smilies/jammin.gif)
Before (stock springs):
![](http://i1104.photobucket.com/albums/h331/dawanous/c8bc9327.jpg)
After:
![](http://i1104.photobucket.com/albums/h331/dawanous/baa31cec.jpg)
![](http://i1104.photobucket.com/albums/h331/dawanous/d17e0105.jpg)
jtf3i (06-13-2012)
Yea I was thinking 350Z H-Tech's for .8/.8 all around(w/ spring mount cut). Think I'll need a front camber kit for that? My tires are still relatively fresh and I was having trouble finding what drop height you'll need camber for. Idc about buying a rear camber, but 400-500 for a front camber kit is a bit rough
